Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 55
Thread: XM Radio observations (FP1.09)
  1. #11
    Jan 2003
    Ruston, LA
    Make sure you get patch 2, it will fix the display issues.
    Also, check to see if you have the cam trigger or lockout set to the same
    port and enabled.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  2. #12
    Jan 2003
    Ruston, LA
    Also, it crashes without the patch.
    When I tell ya'll to patch, everyone needs to
    patch. I often correct issues that are not
    listed. No patch, no support.
    (This is NOT solely directed at you)
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  3. #13
    Elsewhere
    Quote Originally Posted by frodobaggins
    YEAH!
    How about the Wiki?
  4. #14
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    I have frodoplayer installed as well as my XM-direct.. but when I click on the XM radio.. I dont get a list of channels... in fperrorlog.txt I get a error saying that the port is already open... and then a bunch of errors saying the port needs to be open... my XM-direct is plugged into COM1.. and the settings is correct as far as I can tell in fp...
    any ideas?
  5. #15
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    Check all the other settings in FP and make sure you have no com conflicts (like the camera trigger). On another note, you verified that XM is using COM1 through your control panel, correct?
  6. #16
    FLAC chut's Avatar
    Jul 2003
    San Antonio, TX. USA
    OK, I've got FP109 installed. copied over patch one and got no new results. copied over patch two and still don't see anything different. The XMPCR doesn't deliver any audio after a hybernate or now, even when I shut it down through frodoplayer and try to restart it through frodo. I am not sure what you mean by display issues...is this the failure of the highlite to go to the selected channel when you press a preset button?
    Stop Buying New Music CD's.
    Hit The RIAA where it lives.
    Indash Motorized 7", Epia Nehimiah, 512 MB, 80 GB, DVD, Wireless G, XP Pro, XM PCR, Kenwwod 5 Channel 1200 Watt Amp.
  7. #17
    Jul 2004
    I have FP 1.09 installed with a XMPCR and it works great. I've had no issues with it so far.
    Here are my observations:
    I like the simple controls and I find it easier to use than XM's XMPCR software and XtremePCR.
    The font size makes it very easy to see the information
    I like the preset buttons at the bottom.
    Slider control is OK, but needs a button at the top and bottom to allow scrolling line by line up or down.
  8. #18
    Nov 2003
    Marietta, GA
    Chut,
    Let's dissect this problem...
    The machine shows signal and I can move the channels around but I get no audio until I reboot
    Does this mean you DO get auido USING FP109 after you reboot?
    Maybe an optical sound card issue
    Since you have a Nehemiah, can you disable/disconnect/remove your optical sound card and just use the onboard analog card on your mobo? This should tell you if it is a sound card issue. I'd put my money on the sound card as the problem. Especially if you can change channels and communicate with XMPCR.
    Give it a try and let us know what you find. My XMPCR is working pretty well.
    MikeH
  9. #19
    FLAC chut's Avatar
    Jul 2003
    Hi Mike, yes, I can get audio from the rest of FrodoPlayer, I can also get sound from Mediaplayer and the old copy of Aaron player I've got installed on the carpc. That is what led me to believe it is not a problem with Frodoplayer. I also have XMPCar installed and it doesn't function after a hybernate with it open either. Sometimes when I close XMPCar and hybernate it won't function until a reboot. But most times it works just fine. (XMPCar) There is also an area in the soundcard control panel that tells me when there is not any signal coming into the optical port on the sound card whenever it is not functioning. My machine has been really, really slow to startup for about the last five weeks also and has been generating some new exotic noises so I figured I would re-blast the OS partition and start fresh to see where that got me. I'll probably start that this weekend. I can of course go back to the onboard sound but really don't want to do that. The quality of the sound coming from the installed sound card is waaaayyy better than that which the onboard card produces, although not nearly as loud. + there is the optical input that I currently have that I really enjoy, when it is functional. I think Im gonna start from a fresh build and see where we go from there.
    Give it a try and let us know what you find. My XMPCR is working pretty well.[/QUOTE]
  10. #20
    Aug 2004
    Pearland
    Quote Originally Posted by ddogg_777
    ok it was the camera trigger that caused a confilct.. but im still only getting one channel to show up.. it wont display a list of channels...
  1. XM Radio Satellite Locations
    By dug1967 in forum General Hardware Discussion
    Last Post: 05-11-2006, 04:35 PM
  2. XM RAdio
    By vicky_obee in forum FrodoPlayer
    Last Post: 08-31-2004, 02:38 AM
  3. Legality of recording from XM Radio.
    By god_of_cpu in forum Software & Software Development
    Last Post: 08-21-2004, 12:45 AM
  4. XM Satellite like Radio for UK, Europe, Africa, Asia, South America, and More!
    By lerandell in forum Software & Software Development
    Last Post: 04-09-2004, 07:12 AM
  5. xm radio mod/hack
    By dim-8 in forum General Hardware Discussion
    Last Post: 03-17-2004, 11:13 PM
