If you have the skin ready I have a couple of minutes. Will be on and off though at least for a couple of hours (trying to get my furnace working, looks as though I may need a new one)
no prob, when u get the time,
you can use the same radio skin from my 1.0.8 version of the skin, everything is the same for 1.0.9. Just copy over the radio skin folder and the radio.ini file over to the 800x480 skin folder in 1.0.9, start up fp 1.0.9 and it should work.
If you still have 1.0.8 installed just install my skin and place it into the skin folder.
Will do it in a couple. Have to download your 1.0.8 skin
great, thnx a lot![]()
Everything is not the same for 1.08 in the radio skin. You have to define the mini menu.
[H]4 Life
I'm a lesbian too.
I am for hire!
that i know, but the basic skin is the same, isn't it?
remember, just replace my radio skin with frodo's skin, but leave frodo's mini mode pic's in the folder
just in case, add this to the radio.ini file
Code:MINIMENU_LEFT=10 MINIMENU_TOP=81 MINIMENU_WIDTH=18.75 MINIMENU_HEIGHT=15.625 MINIMENU_EXIT_LEFT=0 MINIMENU_EXIT_TOP=0 MINIMENU_EXIT_WIDTH=50 MINIMENU_EXIT_HEIGHT=100 MINIMENU_MINI_LEFT=50 MINIMENU_MINI_TOP=0 MINIMENU_MINI_WIDTH=50 MINIMENU_MINI_HEIGHT=100 BUTTON_MINIMIZE_LEFT=101 BUTTON_MINIMIZE_TOP=101 BUTTON_MINIMIZE_WIDTH=8 BUTTON_MINIMIZE_HEIGHT=13
Here are my findings, sorry for taking so long.
The radio skin works will need to do the following:
-Edit the volume % section, font is too small
-Station section (FM 97.1) needs some tweeking, station not fitting
-Station section when a saved station is selected needs some tweeking, text is jumbled
The following works fine:
-Tune
-Presets
-Volume
-Mute
-Station up/down
Attached are a couple of picks. Sorry compressed down to post. Let me know if you need anything else.
that is great, thnx i will work on that,![]()
so the volume is to the top, out of the circle and the font is small, correct?
for the station, u mean the font is to big?
"-Station section when a saved station is selected needs some tweeking, text is jumbled" ------ what do u mean by this?
if you still have it on, if possible can i get a bigger picture so i can read it better, if not its ok. you can use this site to upload larger files, up to 128kb http://upload.nowherenews.com/
