well, at least it looks beautiful![]()
so the volume is to the top, out of the circle and the font is small, correct? (Yes)
for the station, u mean the font is to big? (Yes)
"-Station section when a saved station is selected needs some tweeking, text is jumbled" ------ what do u mean by this? This may need to be resized in addition to font change. This section seems to have a lot of info could some of the space right below it be allocated to this section?
[H]4 Life
I'm a lesbian too.
I am for hire!
now i know what i need to fix.....thnx a lot
update: almost done with the main menu, got 3 options for you guys![]()
Glad to help. Let me know if you need anything else.
i'll have the radio updated tomorrow, if you can check it again, it would be great..
does the image looks coppy, because the skin was orginially made 848x480, but the native resolution should have been 800x480...
ok here is the updated the file, just replace the radio pic with the old ones, and also replace the .ini file...
the link http://s3.yousendit.com/d.aspx?id=6B...6A645F9ADAFC66 just unzip it.
i change the pic around also, and adjust the font sizes...i had some time.
Getting there. The volume font still needs to be checked. Also the station and preset station names could be moved down a tad
ok, thnx again, here is the adjustments
i have adjusted the volume, hopefully it will be centered this time. and i also lowered the station & preset.....this is worked out right..
when u get the time can u do this again
oh one thing, who is the station save window? does the buttons work right? and the display? almost forgot about that
well, here it are some main menu options, had to add a lot more buttons for this version
let me know which one you are feeling the most
