I'll have to look at it later, I'm busyOriginally Posted by WeeZyFellA
But if someone doesn't get to it first,
I'll try to fix it.
The FM radio does not work because in the radio.ini file the first line says [main] when it should say [radio], Weezy forgot to change that. So you will have to make this change to get the fm radio to work.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
I'll try to fix it.
[H]4 Life
I'm a lesbian too.
I am for hire!
Need Testers!! can some one help test the XM and RADIO for me.
need to know if all the buttons line up, and also if the display are the right size and dont overlap...the volume and all other buttons
here is the file, just add this the skin folder in fp. it is frodoplayers original skin with my xm and radio skin.
last, if you can plz post pic so i can see exactly what needs to be fix
go to post #67 to download the files changes have been made to the files
Here is what it looks like
XM RADIO
FM RADIO
Fixed stuff.
You had some stuff spelled wrong as well.
[H]4 Life
I'm a lesbian too.
I am for hire!
Tested the new radio.ini changes but had problems. Not worth mentioning now, I will try Frodo's new radio.ini with the skin.
800x480 skin is completed, now workin the the 800x600 skin...
i really like the 800x600 --> a lot more room to play with. this will be great
will show pics later. not far from release!![]()
can't wait to see the completed product. Good work
XM Skin Tester Still Needed, plz Help!!
here is the main background for the 800x600 skin
any comments!! scroll size big enough????
in use
