Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Mike's Hybrid XM
  1. #21
    Nov 2003
    Marietta, GA
    BTW. I got XM to work in Frodo
    Great! Tell us what you had to do to get it working so others cn try the same thing.
    MikeH
  2. #22
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    I did what you said Mike,
    First install any patches that Frodo may have from here:Patch Thread !
    Then:
    1) Look in your Device Manager for "USB Serial Port (COMX)". The X is the port number your XM Radio is using.
    3) Then look in FP Settings1 under XM Radio. Put the COM port from above into this Com Port: box.
    4) If this doesn't correct the problem, look in FP Settings2 under FrodoCam. Uncheck the FrodoCam Trigger Enabled checkbox. Also set the ComPort: to some value other than the value you put into the XM Radio settings window.
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
  3. #23
    Jun 2004
    South-Central PA
    Oh yeah, I forgot:
    If none of the above work....punt.
  4. #24
    Nov 2003
    Marietta, GA
    Gosh..it almost sounds like I know what I'm talking about...
    Congrats!
    MikeH
  5. #25
    Jun 2004
    South-Central PA
    Quote Originally Posted by MikeH
    Congrats!
    That's why I ask you experts!
    BTW, (Yes,I've searched) I can't recall whether it's the Routis or the Destinator Nav. software that'll work with Frodoplayer. (or are they the same?)
    I've got SA2005, but I want something that'll integrate with FP. Which one do I get?
  6. #26
    Jan 2003
    Ruston, LA
    Quote Originally Posted by muldrick
    Then:
    5. Also check the lockout port just like the cam trigger.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  7. #27
    Jun 2004
    South-Central PA
  8. #28
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    Neither are embedded as of now, but I think Frodo is embedding Routis for a future version and then maybe another...
  9. #29
    Jun 2004
    South-Central PA
    Allright, Thanks. Guess I'll get Routis, SA2005 kinda sucks.
  1. Using an XM direct as an XMPCR
    By dacndar in forum General Hardware Discussion
    Last Post: 10-17-2004, 02:21 AM
  2. HAHAHA busted for the cable for the XM thing you guys worked SOOO hard on
    By jimmythecow in forum General Hardware Discussion
    Last Post: 10-15-2004, 12:53 PM
  3. Create our own XM receiver since the XMPCR is done with?
    By judoGTI in forum General Hardware Discussion
    Last Post: 09-04-2004, 04:33 PM
  4. XM PCR External App
    By dug1967 in forum MediaCar
    Last Post: 08-04-2004, 11:35 AM
  5. homebuilt XM receiver
    By stevewm in forum General Hardware Discussion
    Last Post: 07-14-2004, 02:00 PM
