Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Mike's Hybrid XM
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Mike's Hybrid XM
    Did this patch: "This is Patch #1, the version number will stay the same.
    Unzip the file, and place frodoplayer.exe in your frodoplayer directory.
    This will stop bbaa from crashing frodoplayer in the background,
    and support the XM direct using hybrid's cable".
    Question is: will XM need to be used as an external app?
    I can't get the XM to work at all through Frodoplayer.
    It work normally. (not through Frodoplayer)
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
    Nov 2003
    Marietta, GA
    Double check which COM port your XM is using. I had the same problem until I switched to the proper COM port.
    MikeH
    Jun 2004
    South-Central PA
    Even though the XM works fine as a "standalone"?
    FLAC SnyperBob's Avatar
    Nov 2001
    Illinois
    do it
    Jun 2004
    South-Central PA
    OK, OK....Settle down.
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    It will fix your problem, stop arguing and just do it.
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    stop backhanding his bootey
    Jan 2003
    Ruston, LA
    You most probably have the cam trigger or lockout set to the same port and enabled.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Jun 2004
    South-Central PA
    Quote Originally Posted by frodobaggins
    Wonderful, how do I change that?
    Sorry that I'm so green at this, but I've tried every com port, up to 10.
    How do I change what you're talking about?
    Jan 2003
    Ruston, LA
    It's in the settings menu. Look.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  1. Using an XM direct as an XMPCR
    By dacndar in forum General Hardware Discussion
    Last Post: 10-17-2004, 02:21 AM
  2. HAHAHA busted for the cable for the XM thing you guys worked SOOO hard on
    By jimmythecow in forum General Hardware Discussion
    Last Post: 10-15-2004, 12:53 PM
  3. Create our own XM receiver since the XMPCR is done with?
    By judoGTI in forum General Hardware Discussion
    Last Post: 09-04-2004, 04:33 PM
  4. XM PCR External App
    By dug1967 in forum MediaCar
    Last Post: 08-04-2004, 11:35 AM
  5. homebuilt XM receiver
    By stevewm in forum General Hardware Discussion
    Last Post: 07-14-2004, 02:00 PM
