Page 11 of 14 FirstFirst ... 234567891011121314 LastLast
Results 101 to 110 of 134
Thread: skin preview_LS_1.0
  1. #101
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Im working on it as i type this
  2. #102
    Aug 2003
    Chicago
    updated to work with take3, plus a few extras.
    LS 1.0
  3. #103
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    Quote Originally Posted by liquid_smoke
    LS 1.0
    im having an issue with your latest skin on frodo 1.09 take 3 patch 1..... the directory lists, and video lists dont show up.... when i switch modes, i just get a frodo logo in the middle of the screen, i get no list of files.... any ideas? am i missing something? also.... when i go to menu screen, it goes back after like 5 seconds to media player.... wasnt there a setting for that? i dont see it there...
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
  4. #104
    Aug 2003
    Chicago
    Quote Originally Posted by Chita79
    The vis or info button when clicked should cycle to the off mode. I think this is broken in FP, i havent been able to cycle with take3, but.... there is a NEW button right under the MUTE button, this toggles the vis on or off also. Try clicking on that, your dir should show up.
    As far as the menu screen going back in 5 sec, this is a setting in FP. I just looked and i also do not see this setting anymore. I do believe there used to be one. But if you look in frodoplayer.ini file, about 20lines down, make your setting look like this
    KEEPMENUOPENUNTILCLICKED=TRUE
    and your menu will stay open
  5. #105
    Aug 2003
    Chicago
    got a question for anyone actively using my skin, as this will affect you.
    Anyone use the mute button? Im thinking of removing it, and putting the VIS button in its place. Makes more since to have that button closer to the button thats currently under the mute button. The area where the VIS button is now will be a new button, not sure what it will do yet. What are your thoughts.
    Also, if you use the OSK what area of the skin are you clicking on to bring the keyboard up? There really is only one area thats the easiest to click without clicking something else, just wanted to check if people want that area to stay the way it is.
    also, does anyone want to see a phone button on the menu screen?
    let me know
  6. #106
    xtm
    xtm is offline
    Oct 2004
    Use Search, NJ
    I don't use it. I (personally) think it's a good move to remove it and replace it with the VIS button (to make the VIS easier to reach and see) My suggestion would be to replace that button with an "EQ" button (the area where the VIS used to be) I don't know if this is even possible though..
    I double-tap that black area right below the last song
  7. #107
    Aug 2003
    Chicago
    Quote Originally Posted by xtm
    below the PL ? I was hoping you were going to say the black area under the FIND button. The small area under the PL and above the track slider is going to be gone. At least while the VIS is showing.
    anyone else have an opinion? ill be making the changes when i get home tonight. I also may be starting to skin the FM section or XM, not sure which one i should start first. Which one do more people find usefull, does anyone even use FM?
  8. #108
    Nov 2003
    West Sussex, UK
    hi, im probably bieng special, but i just downloaded your skin, and i get no text in the main body of your skin for the track or browsing.
    i had a previous version of your skin working, and the font is definatly installed - other programs can see it
    any ideas???
  9. #109
    Aug 2003
    Chicago
    try clicking the button under the mute button, by default i think the area you are looking for is covered up. This button should show it.
  10. #110
    Nov 2003
    West Sussex, UK
    im still bieng special, the button under the mute button is the volume and then menu, both dont help.........
  1. neocar skin workshop Alpha.2a [DOWNLOAD]
    By netsuo in forum NeoCar Media Center
    Last Post: 11-21-2004, 05:33 PM
  2. FRODOPLAYER 1.0.9 SKIN in progess
    By WeeZyFellA in forum FrodoPlayer
    Last Post: 10-27-2004, 10:07 AM
  3. New Skin - Spaced_Out for FrodoPlayer 1.08
    Last Post: 10-17-2004, 10:50 PM
  4. v.3 SKIN
    Last Post: 10-15-2004, 09:29 PM
  5. Laguna Skin
    By CdRsKuLL in forum MediaCar
    Last Post: 06-20-2004, 09:27 AM
