Page 11 of 15 FirstFirst ... 23456789101112131415 LastLast
Results 101 to 110 of 142
Thread: Bug Reports (FP 1.09 Take 2)
  1. #101
    Variable Bitrate Frigor's Avatar
    Aug 2004
    Faenza, Italy
    A shot for the problem with the mini exit menu...
    I'm sad because the "off led" won't light up
    BMW E36 Project [ =======§== ]
    Hardware:
    Lilliput 7" Touchscreen - Epia M-10000 - HQCT 1.0 FM Radio - 2.5" 80Gb - USB GPS
    Software:
    FrodoPlayer 1.10 & MapMonkey with FriBruMet Skins by Frigor.
  2. #102
    Aug 2004
    Germany
    Don't know if this is a bug but here you go. I've a problem with the XM skin. In the screenshot you can see that if I press button 5 the selection is too big, parts of button 4 and 6 are also highlighted. I double-checked my ini file. That doesn't mean I'm sure thats a bug. But in the standart skin is the "rotating" xm-logo at this position. Is this a predefined area ? At least I think this is the cause of the problem.
    Attached are a screenshot and the xm.ini
    Attached Files Attached Files
  3. #103
    Variable Bitrate hevnsnt's Avatar
    Mar 2004
    Ok.. Been testing for awhile and here are some "bugs" I have found
    -When returning from Hibernation the "Hide Cursor Globally" does not work. I see my mouse cursor. I have to go uncheck that box, exit, and then check it again in order for my mouse cursor to be hidden.
    -When returning from Hibernation, when in full screen vis mode, I have to press the next (or previous) song to start playing. It will just sit there all day unless I go to the next song.
    www.i-hacked.com Hardware hacking articles
  4. #104
    It's not really that small...No, seriously. judoGTI's Avatar
    Feb 2004
    Florida
    Quote Originally Posted by Konrad
    Just by looking at it, that is a skinning problem. Maybe sure your width percent for button 5 is correct. I'll take a look at the .ini later tonight after I get dinner and some work done.
    '02 GTI
    [Routis '04] [Opus 90W] [160GB Maxtor HD]
    [Lilliput 7" TS] [VIA M10000] [XMPCR]
    [512MB RAM] [Custom housing]
    [Deluo GPS Mouse] [E-MU 0404 Soundcard]
    Progress Meter: [==============|] 99.9%
  5. #105
    Quote Originally Posted by mi800
    Files with asian letters are always cut off a few letters from the back in window 1 and 2. Although window 3 always displays tag names correctly. English names are displayed correctly in all three windows. Please help me out here. If not, I'm going with resource hog Itunes.
    same problem with chinese charactor to display.....double char set
  6. #106
    Jan 2003
    Ruston, LA
    Quote Originally Posted by judoGTI
    It is a bug, I forgot to add the position settings for the xmsaveinfobutton.
    So it's still sitting exactly where I placed it at design time. Will fix soon.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  7. #107
    Maximum Bitrate vicky_obee's Avatar
    Dec 2003
    Hi in the Mini Mode when i press the play button it changes to PAUSE button .. FINE and also calls out pause. on repressing the same button again to goes to the play icon... BUT STILL CALLS OUT PAUSE..... ( LOL )
  8. #108
    Variable Bitrate Squid's Avatar
    Jan 2004
    Pittsburgh, PA
    Quote Originally Posted by Squid
    Uninstalled old-new frodo and rebooted as instructed... installed take2....
    The directory2 mode still doesnt show the listing of the files inside the directory when I
    select it. You have to double click it and enter the directory for the files to show up
    and be able to play them. All that is left shown above is the "." and ".." for going up a directory.
    Also, the back button is hit-or-miss... mostly it doesn't work tho...
    And is there a way to turn off the "tool tips" in this version?
    thanks for ur help!
    -Squid
    I figured out why it wasn't showing the files inside the directory2...
    I turned recursion off because I have many discography's and I don't
    want FP to jumble all the albums together. Well that's it. If I turn
    recursion back on, then I can see the files in every directory like normal,
    but my nested directories are all one big selection of songs.
    So now that I figured out when it does it... can you figure out why and fix it??? THANKS!!!
    CarPuter: Dell P3-500 Laptop; D-Link WiFi; Deluo GPS; D-Link Radio; iMac DVD w/ ide2usb
    Audio: Audigy 2 NX; Kicker KX700.5 amp; 20w center amp; Kicker L7 10" Sub
    Display: Lilliput 7" TouchScreen
    CarPuter Install
  9. #109
    Jun 2002
    Malaysia
    First of all, great job! I especially like the vis off feature.
    Now take a look at this picture. What I circled I think is the slider. The slider is always at the rightmost. If I click anywhere on the slider, it goes back to the rghtmost and the song restarts.
    EDITED:
    Nevermind, fixed it by downloading all the files listed in the FP FAQ thread. Except for the last two files.
    Fixed the slider bug, but now I cant alt-tab out of FP =(
  10. #110
    Nov 2003
    Marietta, GA
    Frodo, you may want to take a look at the MINI button in XM also. It's a minor nit, but only the right half of the button is active. The left half is dead.
    MikeH
  1. International support in FP 1.09
    By fireball106 in forum FrodoPlayer
    Last Post: 05-26-2005, 09:45 AM
  2. Bug Reports 1.09
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-22-2004, 10:24 PM
  3. Help FP 1.09 Sync
    By bbrother in forum FrodoPlayer
    Last Post: 10-20-2004, 01:22 PM
  4. Replies: 21
    Last Post: 10-18-2004, 01:25 PM
  5. MediaEngine Bug Reports IMPORTANT... READ!!!
    By phat_bastard in forum Media Engine
    Last Post: 02-02-2004, 04:32 PM
