Page 3 of 15 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 142
Thread: Bug Reports (FP 1.09 Take 2)
  1. #21
    Aug 2004
    Germany
    Another problem. My desktop is running 1024x768. I have WinDVD installed.
    When I use advanced screen settings dvds just play fine. But when I turn off advanced screen settings the movie is garbled. I just see alot of green lines, nothing more. When I turn advanced screen settings on again everthing's fine.
    EDIT:
    The cause of the number-bug I described seems to be the track numbers.
    If I disable "Show Track Numbers in Lists" those numbers disappear as they should. Now that I know that it's a problem with the track numbers I don't really understand why. I checked a few MP3s which are showing 00, 01, 32. None of them has a track number stored in the ID3-Tag.
  2. #22
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Am i the only one that noticed that the friggen mini mode still wont stay where you put it.
    Yes i unintalled the old version
  3. #23
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    Mini mode works fine for me now. It stays when you go in and out of mini mode and also goes back there when you exit/restart FP.
  4. #24
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Quote Originally Posted by antimatter
    It does not stay put for me either, but I also can't get out of it either. I have tried 1 tick 2 tick 3 tick and none of them will let me out of it.
    肚子笑痛了
    S60 Install
  5. #25
    Variable Bitrate WeeZyFellA's Avatar
    Oct 2004
    New York
    i have a problem with the LBLEXTRATITLE display, the titles are cramped..any way to add item height to the display,
    i have the same problem with the mode, when it display directory2 and bbaa it overlaps, can this also be adjust through item height?
    check the yellow highlighted area
  6. #26
    Mar 2004
    Redondo Beach, CA
    OK, here is another carry over from all previous versions of FP. For large media collections or slow computers (or both), FP takes so much time constructing the playlist window that it interferes with the proper function of GUI.
    The first case of this I already mentioned in the previous bug thread (i.e. playlist construction causes incorrect detection of on-screen keyboard clicks).
    Today I played with the Directory 2 browsing mode and noticed this problem. If you (accidently?) browse up above the root of your media collection, it is impossible to get navigate back down the tree. Each time you click a directory, the playlist is recomputed/redrawn. Because of this, it's impossible to generate a double click and thus you can never drill back down. Instead, double clicks end up being registered as two single clicks and you get to sit and wait (10+ seconds) while the playlist regenerates (in my case approximately 11000 entries) twice only to find out that the double click didn't register properly.
    It seems like the playlist construction code needs to be re-thought. Perhaps this code can run in a background thread that can then be interrupted if the user clicks another button. On the otherhand, does it ever even make sense for the playlist to have so many entries? For in car use, it's impossible to accurately use the slider to scroll through such a large number of entries. Moreover, the up/down arrows are pretty much useless t0o -- nobody is going to click one of those a thousand or more times to find their track. Maybe the playlist generation code should just stop once more than a preset number of entries are retrieved.
    It's just a thought. I believe this is correctly registered as a scalability bug.
  7. #27
    May 2003
    Miami, FL
    Yeah I have noticed that even with 6000 entries it's a tad slow.
    肚子笑痛了
    S60 Install
  8. #28
    Constant Bitrate Zoltan's Avatar
    Jun 2004
    Shreveport, LA
    DVD's play really choppy for me. Is it that I'm running my DVD+-RW through USB 2.0?... or is everyone having the same prob?
    '03 Escape 4WD:
    -iTox mini-itx mobo, Core 2 Duo Mobile 1.66Ghz; 2GB, 80GB 2.5" HD, DS-ATX
    -Transflective 8.4"
    -XM, iG4, OBD-II (BR-3)
    -Rearview camera with auto-switching (modified cheesbox)
    -Slim Slot DVD+RW
    -RR, DFX 4
  9. #29
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Nicely done. Where could I find documentation? That way I will understand all the features and not ask silly questions...
    TruckinMP3
    Read the FAQ!
  10. #30
    Hey, I love FrodoPlayer, it is amazing! I have found a problem with it however. I'm not sure if this is just local to my machine as I have not tested it in my carputer yet or if it is an actual program bug. Whenever I have a file playing and I exit FrodoPlayer when I restart the program it locks up. If I edit the frodoplayer.ini file to FILE_LAST_PLAYED=NONE
    FILE_LAST_PLAYED_POSITION=0
    it will open just fine. Can anyone else confirm this?
  1. International support in FP 1.09
    By fireball106 in forum FrodoPlayer
    Last Post: 05-26-2005, 10:45 AM
  2. Bug Reports 1.09
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-22-2004, 11:24 PM
  3. Help FP 1.09 Sync
    By bbrother in forum FrodoPlayer
    Last Post: 10-20-2004, 02:22 PM
  4. Replies: 21
    Last Post: 10-18-2004, 02:25 PM
  5. MediaEngine Bug Reports IMPORTANT... READ!!!
    By phat_bastard in forum Media Engine
    Last Post: 02-02-2004, 05:32 PM
