Page 5 of 15 FirstFirst 1234567891011121314 ... LastLast
Results 41 to 50 of 142
Thread: Bug Reports (FP 1.09 Take 2)
  1. #41
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    see
    肚子笑痛了
    S60 Install
  2. #42
    Jan 2003
    Ruston, LA
    got any errors in the log guys ?
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  3. #43
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    here is my error log.
    Attached Files Attached Files
  4. #44
    Jan 2003
    Ruston, LA
    Date a little off ?
    You shouldn't have any of those errors in the log. I suggest you uninstall, delete everything in the directory, and start over with take 2.
    What OS are you using ?
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  5. #45
    A Brit in Las Vegas
    Some issues with the XM player
    1. The title box at the top is a light gray color and has green text that is almost invisible - what am I missing?
    2. How on earth do I program the presets - I selected a channel, listened to it and then held my finger on the 1 preset. All it did was change to channel 1 regardless of how long I held it for.
    3. Also, when hitting MENU from the main screen it takes much longer in Take 2 that it did in 1.09 for the menu to appear (not a bug just an observation).
    4. When setting keyboard shortcuts it doesn't warn you that a key has been used elsewhere - only an issue cos there are 3 screens of shortcuts so you forget which ones have been used (not a programming bug but a design bug)
    The rest seems ok but I'm still testing
    Steve
    RV : Samsung Q1 + Kyocera KR1 (EVDO) + GPS<br>
    Car: AMD 3000+ Book PC + Lilliput 8" Touch + 13" TFT
    Webmaster for the European Ford Scorpio Site
  6. #46
    Jan 2003
    Ruston, LA
    Quote Originally Posted by SteveC
    Adjust your monitor. Please do not report skin dislikes as bugs.
    Select a channel in the list. Hold down for 2 or more ticks.
    No code has changed there.
    This is not a design bug, that is the way it is meant to be.
    You have modifier keys for a reason.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  7. #47
    Jan 2004
    California
    Quote Originally Posted by frodobaggins
    Date a little off ?
    Maybe i am just stuck in the past
    I will try your suggestion tomorrow and post
    I am using XP Pro SP1
  8. #48
    The fperrorlog.txt file is:
    10/23/2004 - 6:49:11 PM - 481 - Invalid picture - MainModule-picresize - 2 - FrodoPlayer -
    10/23/2004 - 6:49:22 PM - 481 - Invalid picture - MainModule-picresize - 2 - FrodoPlayer -
    10/23/2004 - 6:49:27 PM - 481 - Invalid picture - MainModule-picresize - 2 - FrodoPlayer -
    10/23/2004 - 7:04:45 PM - 9 - Subscript out of range - frmDB-lstPlayList_ListIndexChange - 0 - FrodoPlayer -
    10/23/2004 - 7:05:37 PM - 9 - Subscript out of range - frmDB-lstPlayList_ListIndexChange - 0 - FrodoPlayer -
    10/23/2004 - 7:11:36 PM - 481 - Invalid picture - MainModule-picresize - 2 - FrodoPlayer -
    I have uninstalled and reinstalled. I still haven't tried this on another comptuer and won't be able to until tomorrow. I'll play around with it some more when I have more time. Thanks again for the great program!
  9. #49
    Jan 2003
    Ruston, LA
    Quote Originally Posted by abfgry
    Do you have a bug to report ?
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  10. #50
    Maximum Bitrate pyros's Avatar
    Mar 2004
    Toronto, Canada
    not sure if this is exactly a bug but when you select the menu to show on start, fp will first load the form for the player then load up the menu, so you see a flash for about a second of the player before the menu shows up. is there any way in the code that if the menu is selected to start up on load that it just loads the menu first before the player? or atleast still loads the player first but shows the menu form first?
    thanks,
    Chris
    2004 Ford Mustang Mach 1
    Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
    Install Status: DONE
    My XM FAQ
  1. International support in FP 1.09
    By fireball106 in forum FrodoPlayer
    Last Post: 05-26-2005, 10:45 AM
  2. Bug Reports 1.09
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-22-2004, 11:24 PM
  3. Help FP 1.09 Sync
    By bbrother in forum FrodoPlayer
    Last Post: 10-20-2004, 02:22 PM
  4. Replies: 21
    Last Post: 10-18-2004, 02:25 PM
  5. MediaEngine Bug Reports IMPORTANT... READ!!!
    By phat_bastard in forum Media Engine
    Last Post: 02-02-2004, 05:32 PM
