Page 6 of 15 FirstFirst 123456789101112131415 LastLast
Results 51 to 60 of 142
Thread: Bug Reports (FP 1.09 Take 2)
  1. #51
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    im having issues with frododvd, it plays dvd movies really choppy, where if i play the same dvd with Windvd it runs smoothly with no issues, ideas???? also, i notice that frodo's find function doesnt work well. I say this because i tried searching for a specific song within 9000 mp3s, and it did not find a specific mp3 in there that i confirmed is in the database. Also, what is the big difference with take 2 1.09 and the 1.09patch2? .....my last question (a bit off topic)... where can i get a brushed metal skin for 1.09? thanks guys!
  2. #52
    Variable Bitrate Squid's Avatar
    Jan 2004
    Pittsburgh, PA
    Uninstalled old-new frodo and rebooted as instructed... installed take2....
    The directory2 mode still doesnt show the listing of the files inside the directory when I
    select it. You have to double click it and enter the directory for the files to show up
    and be able to play them. All that is left shown above is the "." and ".." for going up a directory.
    Also, the back button is hit-or-miss... mostly it doesn't work tho...
    And is there a way to turn off the "tool tips" in this version?
    thanks for ur help!
    -Squid
    CarPuter: Dell P3-500 Laptop; D-Link WiFi; Deluo GPS; D-Link Radio; iMac DVD w/ ide2usb
    Audio: Audigy 2 NX; Kicker KX700.5 amp; 20w center amp; Kicker L7 10" Sub
    Display: Lilliput 7" TouchScreen
    CarPuter Install
  3. #53
    Jan 2003
    Ruston, LA
    Quote Originally Posted by pyros
    not sure if this is exactly a bug but when you select the menu to show on start, fp will first load the form for the player then load up the menu, so you see a flash for about a second of the player before the menu shows up. is there any way in the code that if the menu is selected to start up on load that it just loads the menu first before the player? or atleast still loads the player first but shows the menu form first?
    thanks,
    Chris
    FrodoPlayer was never designed to have a menu as the center of
    attention. The options for the menu were an afterthought.
    There will be no improvement of this feature.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  4. #54
    Jan 2003
    Ruston, LA
    Quote Originally Posted by Squid
    thanks for ur help!
    -Squid
    Back button works fine. I don't know what is your issue.
    Maybe it's a skin issue (even with default)
    I'll get back to you on the rest.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  5. #55
    Low Bitrate ernie's Avatar
    Jul 2004
    Poland
    starts too quick...
    Frodo!
    This is not a bug really, but it is a big problem for me. Since I've got the problem with soundcard (as I read the forums I know I'm not alone)- it wakes from hibernation with master volume set on 100% i am using your program to "setvolume.exe 30" in "settings->resume". It worked nice in FP Alpha 1m, but FP Take 2 resumes play too quickly- this allows few beats to be played at full blast before "setvolume.exe" adjusts the volume to proper level. Can you make play to resume halve a second later? Or maybye an option to resume a play at adjustable level?
    It would be a nice feature if we could adjust dalay after which play resumes- we could put something like announcement (just for fun or for security purposes), but I won't mention about it now since it would be a feature request
    Ernie
  6. #56
    Oct 2004
    San Diego, CA
    FRODO, please try to answer my questions.... im having issues with frododvd, it plays dvd movies really choppy, where if i play the same dvd with Windvd it runs smoothly with no issues, ideas???? also, i notice that frodo's find function doesnt work well. I say this because i tried searching for a specific song within 9000 mp3s, and it did not find a specific mp3 in there that i confirmed is in the database. Also, what is the big difference with take 2 1.09 and the 1.09patch2? .....my last question (a bit off topic)... where can i get a brushed metal skin for 1.09? thanks guys!
  7. #57
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Quote Originally Posted by WeeZyFellA
    on resume from exit, the song continues from where it was left off as it should, but the the info in extra lablel title is not displayed on resume, but bitrate and duration does show. can this be fix?
    Yeah, Frodo, what up with this. Does the same for me as well.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  8. #58
    Jul 2004
    NL, Druten
    Quote Originally Posted by Quattro-A4
    click again on the play button fix it :P
  9. #59
    Quote Originally Posted by frodobaggins
    Do you have a bug to report ?
    Hi,
    My original post was at the bottom of the second page. I have tried 1.09(t2) on another computer and it seems to work just fine. I'm assuming it is something going on with this computer. Thanks for the great work.
  10. #60
    May 2004
    Texas
    i have a issue with xmdirect ,frodo xm configured with the right comm port using fp take 2 .when i go to the xm screen nothing happens even after shutting the pc down but if i use hybrid mikes xm prog first and then fp ,xm works fine till i turn power off
  1. International support in FP 1.09
    By fireball106 in forum FrodoPlayer
    Last Post: 05-26-2005, 10:45 AM
  2. Bug Reports 1.09
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-22-2004, 11:24 PM
  3. Help FP 1.09 Sync
    By bbrother in forum FrodoPlayer
    Last Post: 10-20-2004, 02:22 PM
  4. Replies: 21
    Last Post: 10-18-2004, 02:25 PM
  5. MediaEngine Bug Reports IMPORTANT... READ!!!
    By phat_bastard in forum Media Engine
    Last Post: 02-02-2004, 05:32 PM
