Results 1 to 10 of 11
Thread: DVD skinning problem
    Aug 2004
    Germany
    I have a problem skinning the DVD menu. All buttons are fine exept the exit menu.
    This is part of Frodos DVD.ini:
    MINIMENU_LEFT=8.7
    MINIMENU_TOP=0
    MINIMENU_WIDTH=18.75
    MINIMENU_HEIGHT=15.625
    MINIMENU_EXIT_LEFT=0
    MINIMENU_EXIT_TOP=0
    MINIMENU_EXIT_WIDTH=50
    MINIMENU_EXIT_HEIGHT=100
    MINIMENU_MINI_LEFT=50
    MINIMENU_MINI_TOP=0
    MINIMENU_MINI_WIDTH=50
    MINIMENU_MINI_HEIGHT=100
    This is what I have in my DVD.ini:
    MINIMENU_LEFT=0
    MINIMENU_TOP=0
    MINIMENU_WIDTH=28.7
    MINIMENU_HEIGHT=23.75
    MINIMENU_EXIT_TOP=0
    MINIMENU_MINI_TOP=0
    As you can see I just changed the size of the minimenu box. But as I understand MINIMENU_EXIT_WIDTH=50 and MINIMENU_EXIT_HEIGHT=100 means that the exit button is 50% the width and 100% the height of the minimenu box. However the selection stays small. I'm sorry, I can't describe it better. I made a screenshot for you to see. I don't know if it's a bug or just me doing something wrong.
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    Hey, Frodo, I've noticed something smilar in your orignal skin as well. when you click the exit button, the exit menu pops up fine and the buttons work fine as well. But when you click on the mini button you have to go all the way to the right to press it and when you do press it only half of the button changes to the down button. Wezzyfella, is also having the samething on his exit menu, for the mini button. He hasn't been able to fix it either, I don't know if it a bug or something wrong in the .ini file. I played around wiht the values in the .ini file but was not able to fix it.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Jul 2004
    NL, Druten
    The solution is simple..
    You can only put one option (button) at a place You are now trying to place two buttons at the same spot... They both start at (left) 0 and top (0)
    Capice??
    MINIMENU_LEFT=0
    MINIMENU_TOP=0
    MINIMENU_EXIT_TOP=0
    Dec 2003
    New York
    I don't think that should be problem. The MINIMENU_LEFT=0 and MINIMENU_TOP=0 just tell where the placement of the mini menu is. The MINIMENU_EXIT_LEFT=0 tell where the exit button is with in th minu menu.
    Installed
    Dec 2003
    New York
    here what I'm talking about. I haven't been able to fix it in the .ini file.
    Konrad's problem may be related to this.
    Installed
    Variable Bitrate WeeZyFellA's Avatar
    Oct 2004
    New York
    the problem that konrad & quattro stated isn't only in the dvd mini menu, it happens in all of the mini menus.......i haven't figured out how to fix it.
    Jan 2003
    Ruston, LA
    Quote Originally Posted by WeeZyFellA
    Because it's a bug
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Oct 2004
    New York
    can it be fixed,
    Jan 2003
    Ruston, LA
    can it be fixed,
    It's already fixed, will be in next release.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Variable Bitrate Frigor's Avatar
    Aug 2004
    Faenza, Italy
    Quote Originally Posted by frodobaggins
    Sorry, wich release? In 1.0.9 Take 2 it continue doing the proble...
    But it isn't a real problem... The program rocks!
    Goooood work Frodo!
    BMW E36 Project [ =======§== ]
    Hardware:
    Lilliput 7" Touchscreen - Epia M-10000 - HQCT 1.0 FM Radio - 2.5" 80Gb - USB GPS
    Software:
    FrodoPlayer 1.10 & MapMonkey with FriBruMet Skins by Frigor.
  1. Skinning Problem (possible bug?)
    By Konrad in forum FrodoPlayer
    Last Post: 10-03-2004, 04:18 PM
  2. DVD files from Harddisk in MediaEngine..?? HOW?
    By clemen in forum Media Engine
    Last Post: 05-23-2004, 05:21 PM
  3. Replies: 2
    Last Post: 05-11-2004, 12:07 AM
  4. DVD Interface Question (Looking for suggestions)
    By GTC in forum Software & Software Development
    Last Post: 06-12-2003, 09:44 AM
  5. Replies: 4
    Last Post: 03-16-2002, 02:32 AM
