Im experimenting with FP 1.09 since it has XMPCR support and Im trying to modify the skin a bit to work on 640x480, but I would also like to change the colors a bit trying to remove the black backgrounds and brighten it up.
I looked around the settings and am trying to change the TEXT color. Right now its yellow. I didnt see any choices for text color changes, so I assume its in the skin ini files. If so, where can I find it?
Also, trying to figure out how to change the other colors. I see there are numeric values in Dec format. So I tried to change the background color to a light blue which is HEX C7DBFF. When I convert to dec I get 13097983, but after updating the ini file it shows up as a yellow-brownish color.
What am I doing wrong?
G945GLCF2 | 512MB RAM | 160GB HD | Holux GPS w/ Routis | XMPCR w/ TOSLINK mod | Audigy 2 NX | | Xenarc 700TSV |Opus 150W PSU.
[H]4 Life
I'm a lesbian too.
I am for hire!
thats helpful frodo... dont need a calculator to do it anymore
yes, very helpful - thanks frodo.
edit: i figured out that question.
I have a sin question. If I am making a skin, and dont want a button on there, do I set the = to nothing? Or to a zero? Thx!
'02 GTI
[Routis '04] [Opus 90W] [160GB Maxtor HD]
[Lilliput 7" TS] [VIA M10000] [XMPCR]
[512MB RAM] [Custom housing]
[Deluo GPS Mouse] [E-MU 0404 Soundcard]
Progress Meter: [==============|] 99.9%
u have to set any button that u dont want to greater then 100 for both the top and the left.
so
left = 105
top=105
width=0
height=0
that should help
Don't set the width and height to 0, could potentially cause problems.Originally Posted by WeeZyFellA
Moving the left & top are sufficient.
[H]4 Life
I'm a lesbian too.
I am for hire!
ooppss... slipped.. thnx frodo
Could you take a look at this pic and my ini to see where I am messing up? I labeled everything for you, but the words wont be there in my finished product.Originally Posted by WeeZyFellA
http://jan.ucc.nau.edu/~rwh3/brian_save/carpc/skin.INI
'02 GTI
RAIL_HEIGHT=464
u sure u want the height that much....
what seems to be the problem?
