I don't really play my music at high-volumes, but with a good mic (I use a 1/8" logitech noise-canceling mic) when its mounted close to your mouth is very good.Originally Posted by Jackso
turn the volume way down or off. i mean it can't be really loud but you can do it.
CarPC install is starting to come along again...
i was wondering way play pause and all of that didnt work, i'll try maximizing frodo
why don't use use winsock commands? 1.09 supports that, right? the whole fpwebserver thing...thats what it was all about, and it would be a much cleaner way to do it.
NaviVoice v.9 Release
Well, this has practically full Frodo support. I forgot about fixing the min/max/bug.
Supported commands:Remeber! All of these are user configurableCode:<p val="406">open frodo</p> <p val="407">close frodo</p> <p val="408">minimize frodo</p> <p val="409">restore frodo</p> <p val="410">maximize frodo</p> <p val="411">focus frodo</p> <p val="500">previous</p> <p val="501">rewind</p> <p val="502">play</p> <p val="503">stop</p> <p val="504">pause</p> <p val="505">next</p> <p val="506">fast foreward</p> <p val="507">shuffle</p> <p val="508">repeat</p> <p val="509">volume up</p> <p val="510">volume down</p> <p val="511">mute</p> <p val="512">playlist down</p> <p val="513">playlist up</p> <p val="514">directory down</p> <p val="515">directory up</p> <p val="516">fullscreen mode</p> <p val="517">mode back</p> <p val="518">mode foreward</p> <p val="519">mode change</p> <p val="520">visualization down</p> <p val="521">visualization up</p> <p val="522">mini mode</p> <p val="523">playlist select</p> <p val="524">volume down two</p> <p val="525">volume up two</p> <p val="530">what is my volume</p> <p val="531">is frodoplayer mute</p> <p val="532">is frodoplayer plaing</p> <p val="533">what is the frodoplayer mode</p>
And yes, this uses the windows sendmessage commands. Hats off to Kevin for making this easy to translate. VB code is just as easy to read as Delphi. I'll post the two programs to compare their complexity and give users an example of something that does the same thing written in two different languages![]()
alrighty! any chance you could show me some of your source code by the way? i'll look to see if there are examples of getting SAPI working with VB but i'm kinda curious how its done.
I don't like VBOriginally Posted by Grayscale
This is 100% Delphi
About as easy to code as in VB, and it runs faster
Code in VB from Frodo Commands:Same code in Delphi:Code:Case 1 Select Case RemoteInfo(CLng(Index + 1)) Case 1 txtFrodoInfo(Index).Text = "M_ALBUM" Case 2 txtFrodoInfo(Index).Text = "M_ARTIST" Case 3 txtFrodoInfo(Index).Text = "M_GENRE" Case 4 txtFrodoInfo(Index).Text = "M_DIRECTORY" Case 5 txtFrodoInfo(Index).Text = "M_ALL_MUSIC" Case 6 txtFrodoInfo(Index).Text = "M_ALL_VIDEO" Case 7 txtFrodoInfo(Index).Text = "M_CD" Case 8 txtFrodoInfo(Index).Text = "M_PLAYLISTS" Case 9 txtFrodoInfo(Index).Text = "M_FAVORITES" Case 10 txtFrodoInfo(Index).Text = "M_BBAA" Case 11 txtFrodoInfo(Index).Text = "M_BBD2" Case 96 txtFrodoInfo(Index).Text = "MM_DVD" Case 97 txtFrodoInfo(Index).Text = "MM_FM" Case 98 txtFrodoInfo(Index).Text = "MM_XM" Case 99 txtFrodoInfo(Index).Text = "MM_SETTINGS" Case Else txtFrodoInfo(Index).Text = "UNDEFINED" End Select
As you can see, the two languages are very similar. Remember, this is the same exact command.Code:Case i of 1: showmessage('M_ALBUM'); 2: showmessage('M_ARTIST'); 3: showmessage('M_GENRE'); 4: showmessage('M_DIRECTORY'); 5: showmessage('M_ALL_MUSIC'); 6: showmessage('M_ALL_VIDEO'); 7: showmessage('M_CD'); 8: showmessage('M_PLAYLISTS'); 9: showmessage('M_FAVORITES'); 10: showmessage('M_BBAA'); 11: showmessage('M_BBD2'); 96: showmessage('MM_DVD'); 97: showmessage('MM_FM'); 98: showmessage('MM_XM'); 99: showmessage('MM_SETTINGS'); Else showmessage('UNDEFINED'); end;
you have too many function characters in yours
just kidding man, i prefer languages that are well structured like PHP as well. but ya gotta love how quick you can slap a program together in VB
EDIT: I meant FUNKY not Function
Just because a language lets you do something doesn't mean you have to.Originally Posted by Grayscale
Keeping code structured is a discipline.
[H]4 Life
I'm a lesbian too.
I am for hire!
*Please* try DelphiOriginally Posted by Grayscale
Look up the differences, and you'll see why I chose Delphi. BTW: I used to program in VB, and the only thing I can say is that I'm still trying to recover, VB promotes messy code with 'Option Explicit'.
Agreed. I thikn Delphi's code structure is good, but I find it hard to find stuff because I don't put comments next to any of my functionsOriginally Posted by frodobaggins
I have to say that your code is pretty clean
OMG, "Option Explicit" requires you to declare your variables before using.Originally Posted by 0l33l
Which you should always do.
[H]4 Life
I'm a lesbian too.
I am for hire!
