Then all I will here is, FrodoPlayer takes up my whole screen ! How do I fix it ?!Originally Posted by d_sellers1
It never ends.
Just answered the same problem over in the Take 3 Bugs thread...... Frodo, maybe you should make that unchecked by default to cut down on some of the problems...
Derek
Progress [||-------]
View my Worklog to see some of my progress.
Downgraded Progress - Starting with another car... 09/13/06
It never ends.
[H]4 Life
I'm a lesbian too.
I am for hire!
Good point. Lol. Okay. How about make it an option when FP first gets installed:Originally Posted by frodobaggins
Choose one:
Install as Full Screen
Install as Windowed
User will choose and then the installer will place the appropriate .ini into the directory. Just another option. Maybe they'll get ****ed off saying that it takes too long to install FP.
Derek
Originally Posted by hevnsnt
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
it's 133T talk. he meant ownedOriginally Posted by Quattro-A4
"The dynamic link library GDIPLUS.DLL could not be found in the specified path C:\Program Files\Frodoplayer..." is the beginning of the error that I'm getting. I've downloaded all the other software referenced in the FAQs with the exception of FP1.0.1. I don't get it - one set of instructions says to delete all previous versions of FP and another set of instructions says 1.0.1 is needed for FP to work.Originally Posted by NRGZ28
I've searched on this error and here's the link I came up with... with no resolution that I see. All help would be greatly appreciated.
Much obliged!Originally Posted by wysocki
Quattro, I got the fix from you, and see that I need to toggle off advanced screen settings, "what am I turing off" when I do this, obviously like others, I need to do it, only half the screen is available, but at the same time, I read frodo did it as default because if he didnt, others would ***** about that. just curious why it works for some (since the option is there) but does not for others?Originally Posted by Quattro-A4
SD
if you have it set to true, then the numbers you quoted determine the sizeOriginally Posted by septicdeath
and position. If you have it set to false, FP is full screen and those numbers
do nothing.
[H]4 Life
I'm a lesbian too.
I am for hire!
