Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: small fp feature request - album art modification
  1. #11
    Variable Bitrate blurp's Avatar
    Sep 2003
    Hampshire, TN
    Also, how did you run this command? did you run it from a command prompt, or from the Start-->Run and type it in there?
    You need to open a command prompt, then change directory to the parent directory of all your album folders. Then run it from there.
    So if you have a folder named "Music" on your C: drive that has multiple folders under it, you need to cd\music and then run the command.
    www.bradleyjacobs.com
    There is more stupidity than hydrogen in the universe, and it has a longer shelf life. -- Frank Zappa
  2. #12
    Jul 2004
    blurp and d_sellers1:
    I ran from start->run->command, in the correct directory, with admin privileges, none of the files open.
    Here is what is wierd that I failed to mention before - if I type the code as posted in your initial post:
    Code:
    for /r %%I in (*-*.jpg) do copy "%%I" "%%~dpIalbum.jpg"
    then the command WORKS! It names all the album covers as "album.jpg". If I change only the text "album" in the above code to "folder" - then I get the access denied message. Wierd???!!! Why is that?! I want the files named as "folder.jpg", not "album.jpg"
  3. #13
    Sep 2003
    Hampshire, TN
    That's really strange, I just tried it with folder, and it worked for me. What OS are you using?
    Edit: OH! do you already have some files named folder.jpg in some of the folders? If so, run the command that d_sellers1 posted, then run this to delete all of them:
    Code:
    for /r %%I in (folder.jpg) do del "%%I"
    and see if it gives you any errors. This will tell you if one of the folder.jpg files is locked by something.
  4. #14
    Jul 2004
    I didn't delete 2 jpg files before running the command as they were for an album that was unreleased and couldn't be retrieved by the album art downloading programs...
    I guess these 2 jpg files were causing the problem! I did the attrib command and then tried again and now it works! I've got "folder.jpg" in every album folder now! Thanks for the help guys!!!
  5. #15
    Sep 2003
    Hampshire, TN
    WooHoo! The command prompt king wins again!
    Glad I could help.
  6. #16
    Constant Bitrate RX7FDTT's Avatar
    Dec 2003
    For Windows XP SP2 (Tested)
    Copy this into a text document and save it as AlbumArt.bat in your MyMusic or whatever folder, then open a command prompt or just execute from explorer...
    <<Code Follows do not use this line in bat file>>
    @echo Album Art Generation
    @echo off
    attrib -S -H -R f*.jpg /S
    FOR /R %%I IN (F*.jpg) DO copy "%%I" "%%~dpIalbum.jpg"
    @echo on
    <<Code Done, do not use this line in bat file>>
    This will grab all your hidden folder.jpg files and make them album.jpg(s)
  1. Album art downloader
    By hijinks21 in forum Software & Software Development
    Last Post: 07-20-2006, 10:56 AM
  2. Does/Will FP show album art by....
    By rbarr110 in forum FrodoPlayer
    Last Post: 09-12-2004, 07:28 AM
  3. Album Art Display
    By MANIFESTO66 in forum FrodoPlayer
    Last Post: 06-09-2004, 04:05 PM
  4. Ripping to MP3 WITH album art?
    By coachreed in forum General MP3Car Discussion
    Last Post: 05-20-2004, 07:19 AM
  5. Feature request - for small LCDs
    By ojaneri in forum MediaCar
    Last Post: 11-15-2003, 11:47 AM
