Results 1 to 4 of 4
Thread: FrodoCam Trigger?
    Mar 2004
    FrodoCam Trigger?
    How sound the cam be trigger via serial port. The options there but how would you say link the reverse light to the serial port as such to trigger frodocam?
    cheers
    Jamie
    Elsewhere
    Quote Originally Posted by live2themaxuk
    I'm not the authority here, but I get the principle....
    But you'd basically tie the backup light to a specific pin on a serial connector (I don't know the pinout for the serial port, so I don't know which one). When you shift into reverse, the backup lights come on and power goes to that specific pin.
    FrodoPlayer detects that trigger and launches the cam application so you can see behind you without having to do anything other than put your car in reverse.
    Someone else help the man out with the pin-out for a serial port to accomplish this.
    How about the Wiki?
    Maximum Bitrate Bravellir's Avatar
    Dec 2003
    Porto, Portugal
    I really donīt know if you sould DIRECTLY connect anything on your car electrical system to any of the pc inputs. Think you need to use a relay at least.
    The circuit needed is described here Simply serial input circuit
    Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
    Status -->
    Lilliput Installed (not indash yet..)
    BraveCar 2.5
    Mar 2004
    cheers lads
  1. PAC TR-7 Trigger Module
    By archimense in forum General Hardware Discussion
    Last Post: 04-07-2008, 06:02 PM
  2. FrodoCam
    By frodobaggins in forum Software & Software Development
    Last Post: 11-21-2004, 06:09 PM
  3. Replies: 4
    Last Post: 10-17-2004, 09:58 AM
  4. Replies: 1
    Last Post: 09-18-2004, 04:43 PM
  5. FrodoCam 1.1 Review
    By antimatter in forum FrodoPlayer
    Last Post: 08-19-2004, 01:19 PM
