Page 1 of 6 123456 LastLast
Results 1 to 10 of 51
Thread: FP as Shell??
    Variable Bitrate Dracos's Avatar
    United Kingdom
    FP as Shell??
    Frodo, have you thought about setting FP as shell?
    I have just manually done it, and its really really great! It would be even better if you set an option for it in the FP settings!
    Jan 2004
    NYC
    what do u mean "shell". how would we do it manually?
    Elsewhere
    Quote Originally Posted by camsgs3
    It loads instead of Explorer as the Windows front end.
    You do it manually by changing the registry to load FrodoPlayer instead of Explorer at boot.
    How about the Wiki?
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    When you run windows you are in a shell enviroment. currently you are running the explorer shell. You can replace this shell with others that are more efficent and faster.
    Here are couple of site for you to find out more info abou them.
    http://shell-shocked.org
    http://shellcity.net/
    http://www.shellfront.org/
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    United Kingdom
    thats right, or you can just have one program load up as the 'shell' - super quick!
    Ive added all my most used apps in FP's apps, so I can get at them anyways.
    My comp is now super super fast (should be for its spec anyways!!).
    I can show you how it is done should you need/want it.
    I also repeat my question to frodo about the option to have fp as shell.
    Newbie Fher's Avatar
    Mar 2004
    a step by step tutorial will be appreciated , for the lazy asses like me...
    United Kingdom
    Quote Originally Posted by Fher
    here goes then.
    Click START
    Click Run
    Type: Regedit
    Navigate: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
    On the top toolbar, Click file, then export, choose a filename, then save somewhere safe.
    Back in the main window on the right:
    Select 'Shell'
    Double click to edit.
    Change the path from 'explorer.exe' to the program path. e.g C:\Program Files\FrodoPlayer\FrodoPlayer.EXE
    Click OK
    Close Regedit
    REBOOT!
    When you reboot, frodoplayer will be the only thing to run!
    Then it is up to you to configure frodo app's to open what you want. I added:
    Windows Explorer
    MSN Messenger
    Mozilla Firefox (I hate IE)
    but you can add whatever you want!
    NOTE: I dont accept responsibilty if you mess up your computers!!!!!
    That file you saved is your *** saver - should you want your normal explorer shell back from startup, just navigate to where you saved the file (in windows explorer) and run it. Reboot and you will have explorer shell back.
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    It seems like this was brought up before and the answer was something to the effect of waiting for the bugs to be worked out first. I know once I get my system working 100% I will be replacing the shell with frodoplayer, with or without the option in the settings
    2005 Ford Focus ST
    United Kingdom
    well, it certainly seems like i dont have any problems at the moment. Everything seems very very smooth - no bugs. And yea, who cares about the option eh? - the only reason i decided to ask was because I am liking it so much that i feel others would benefit from it - and it would certainly be a bonus not having to fk about in the registry to get it to do so.
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Are there any negative effects? What happens if the FP crashes? any way to get the shell back? does a double click on the desktop get it back? I seem to remember that brought explorer.exe back, somtimes....
  1. Back and forth FP <-> D3-frontend
    By swissRv in forum Map Monkey
    Last Post: 11-08-2004, 03:53 AM
  2. Boy this is annoying - No volume in FP
    By voidunknown in forum FrodoPlayer
    Last Post: 10-20-2004, 12:18 PM
  3. Basic install Instructions for new FP user
    By eazyrog in forum FrodoPlayer
    Last Post: 10-13-2004, 05:04 PM
  4. Humble thoughts about FP...
    By technopsych in forum FrodoPlayer
    Last Post: 07-12-2004, 11:58 PM
  5. new windows shell & 'shell=' for win2K
    By magnetik in forum Software & Software Development
    Last Post: 04-16-2002, 08:47 PM
