Results 1 to 7 of 7
Thread: Frodo in RamDrive
    Oct 2004
    Australia
    Frodo in RamDrive
    Hi
    I have got my carPC up and running ( still waiting for the screen ). It's a Via Epia-V 533Mhz with 1 Gb of RAM.
    Would it be worth running Frodo from a RamDrive. It's a little slow transitioning between screens, eg: the main screen and the settings screen. I was also thinking of loading Destinator into the RamDrive (including the maps).
    Any thoughts?
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    you would have to install them both to the ram drive.. and during startup.. copy the files back to their correct locations after the ram drive is created... before frodo would run..
    i personally think the time lost in copying back and forth during startup is not worth the performance increase youwould get from running it off the ram drive...
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Massachusetts
    A real ramdrive? cuz those are big money
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
    Oct 2004
    Australia
    Nope - just a prog that creates a virtual drive in RAM and assigns it a drive letter. After everything is running, I've got about 300mb of free unused memory, so if Frodo did a lot of disk access stuff while it's running, it would seem that this would help make it run better.
    Of course, ideally, I would like to be able to copy the 'next' mp3 from disk into the RamDisk, and play it from there, instead of streaming from the disk all the time, then before that song finishes, copy the next one into Ram etc etc.
    Would save wear and tear on the disc anyway....
    Aug 2004
    Pearland
    how fast is your hard drive?.. is write-behind caching enabled on it ?
    I have a 7200 RPM drive.. and although I notice a lag between screens.. well only between XM and the main menu... everything else runs fast...
    if my EPIA supported SATA.. I would have gotten a 10,000 rpm drive..
    Constant Bitrate SuzukiAerio's Avatar
    Aug 2004
    PA, USA
    I really dont think it would be worth it either - if you have a decent speed proc - you are getting all the speed out of frodo that you will prolly see.
    Also the time of copying stuff back will mean longer boots times for a near $null improvment
    ...just my thoughts, let us know how it works for you if you decide to do it
    2002 Suzuki Aerio Sedan ...NOT the stupid wagon
    Jan 2003
    Ruston, LA
    There are some inefficiencies in the way frodoplayer switches screens, I am slowly
    correcting them.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  1. frodo, help on DVD
    By dragonBTV in forum FrodoPlayer
    Last Post: 11-10-2004, 04:54 AM
  2. What else is up your bag of tricks frodo?
    By nappyjim in forum FrodoPlayer
    Last Post: 10-26-2004, 01:57 PM
  3. Hi-res video playback in Frodo
    By TheKingPlaza in forum FrodoPlayer
    Last Post: 09-22-2004, 05:56 AM
  4. Emmbeding gps into frodo player window?
    By jermkesler in forum FrodoPlayer
    Last Post: 08-15-2004, 07:01 PM
  5. Switch between Frodo player and GPS (IGuidance)?
    By Nanozic in forum FrodoPlayer
    Last Post: 07-12-2004, 02:58 AM
