Results 1 to 3 of 3
Thread: FP Position Problem
    Nov 2004
    Frankfurt am Main / Germany
    FP Position Problem
    Hi there, got a big problem with FP: When I set a resolution 800x600 the lower part of FP is below the screen...
    any ideas?
    It's not really that small...No, seriously. judoGTI's Avatar
    Feb 2004
    Use the search.
    It's starts with 'Advanced' and ends with '.ini' and it is a checkbox.
    '02 GTI
    [Routis '04] [Opus 90W] [160GB Maxtor HD]
    [Lilliput 7" TS] [VIA M10000] [XMPCR]
    [512MB RAM] [Custom housing]
    [Deluo GPS Mouse] [E-MU 0404 Soundcard]
    Progress Meter: [==============|] 99.9%
    Variable Bitrate The Grinch's Avatar
    Jun 2004
    Toronto, Canada
    I had this problem with older versions (as well as this one) until someone pointed me in the right direction. I think it happens enough that maybe it should be user setting as part of the installation process. Because once it's installed, you can't access the configuration options properly (the screen is cut off), and notepad is the only solution. It's kind of annoying for touch screen users because then you have to drag out and plug in a keyboard. I realize it's a minor inconvenience (and isn't considered a bug), but it's the little quirks that make a program feel unpolished.
    Carputer progress meter: [-----|]
    Carputer gadget meter: [--|---]
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 08:29 AM
  2. Media Car not responding... Lilliput problem?
    By carpcnoobie in forum MediaCar
    Last Post: 09-01-2004, 01:38 PM
  3. Humble thoughts about FP...
    By technopsych in forum FrodoPlayer
    Last Post: 07-12-2004, 11:58 PM
  4. cordless phone problem
    By jstrain in forum Off Topic
    Last Post: 06-24-2003, 11:09 AM
  5. Replies: 8
    Last Post: 12-31-2002, 11:37 AM
