Page 4 of 7 FirstFirst 1234567 LastLast
Results 31 to 40 of 70
Thread: Equalizer Solution
  1. #31
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    There are two ways to use an equalizer with WMP.
    Either A: hack your own WMP skin to allow you to adjust the WMP equalizer programmatically
    http://www.msdn.microsoft.com/newsgr...6-eced67ce9e83
    or B:
    Write your own directshow transform filter that takes in the unequalized data buffers it for a few milliseconds, equalizes the buffered data, then outputs the buffered stream.
    I have verified both of these work, but they do require C++ to implement.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
  2. #32
    SWC
    SWC is offline
    Aug 2004
    Baltimore
    Quote Originally Posted by Nic
    Nullsoft was good! all the original developers of winamp have now left because of it being an AOL company
    I totally agree, it all went downhill starting with 3, 5 was a great improvement, but every week im reading about new security flaws.
  3. #33
    Variable Bitrate NRGZ28's Avatar
    Oct 2004
    Las Vegas
    What kind of "security flaws" can there be in a MP3 player !?! You play the file and that's it...
    Current Setup
    Nexus 7 Tablet
    Built in head unit
    Brutus 1500Watt Amp
    Two Boston 12" subs
    2006 Infiniti M45 Sport ;) My 4 door Camaro... lol
  4. #34
    Nic
    Nic is offline
    FLAC Nic's Avatar
    Oct 2003
    Melbourne, Australia
    you could say the same about jpeg couldnt you
    Signature: [==||========] 20% complete
  5. #35
    Oct 2004
    Las Vegas
    Yeah.. I guess.... So what harm can a jpeg cause ?
    Current Setup
    Nexus 7 Tablet
    Built in head unit
    Brutus 1500Watt Amp
    Two Boston 12" subs
  6. #36
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by NRGZ28
    Well, if a file isn't formatted correctly it could cause a buffer underrun which will let a hacker take control of your computer.
  7. #37
    Variable Bitrate Dracos's Avatar
    United Kingdom
    Quote Originally Posted by 0l33l
    thats all i gotta say.
  8. #38
    Oct 2004
    Las Vegas
    If a file isn't formatted correctly the imaging software just wont display it. Besides... you can't run code embedded in JPG files... otherwise I'm sure every wanna be "hacker" out there would take advantage of it... not to speak of porn sites who already install spyware behind your back.... !!
    Current Setup
    Nexus 7 Tablet
    Built in head unit
    Brutus 1500Watt Amp
    Two Boston 12" subs
  9. #39
    Oct 2004
    Las Vegas
    Quote Originally Posted by Dracos
    Yeah... uh huh....
    Current Setup
    Nexus 7 Tablet
    Built in head unit
    Brutus 1500Watt Amp
    Two Boston 12" subs
  10. #40
    Aug 2004
    Germany
    That's what I also thought.
    Do you update your XP regularly ? Yes ? Do you check what you install ?
    Microsoft found a security hole which makes you able to add malicious code to a JPG which could be executed when this picture is shown in Internet Explorer.
    You can find infos about this in the Microsoft Knowledge Base.
    So....
    Yes, you can. And it's Microsofts Fault.
    Right. That's not possible in any other software. Just in Internet Explorer. It's an IE problem.
    Microsoft offers a patch which is also installed when you run WindowsUpdate. So no chance for hackers if you update your system regularly. But there are enough people who don't.
    Raising the BS-Flag is easy, I know.
  1. equalizer
    By psych0sys in forum Software & Software Development
    Last Post: 03-25-2008, 08:25 PM
  2. Solution for your audio from "COMPUTER TO SPEAKERS"
    By emayers04 in forum General Hardware Discussion
    Last Post: 10-15-2004, 03:03 PM
  3. Help me pick a solution please
    By electron in forum Newbie
    Last Post: 09-14-2004, 01:02 PM
  4. Aux. input adapter vs equalizer
    By Dima in forum General Hardware Discussion
    Last Post: 09-13-2000, 11:46 AM
