Results 1 to 6 of 6
Thread: still no xm!
    Maximum Bitrate nFiniteTuning's Avatar
    Albuquerque, New Mexico, United States
    still no xm!
    I just downloaded the new FP, never used it...but since I couldn't get MMC to run XM, I'd give it a try. But no go, nothing! MMC says there is no radio hardware, frodo does nothing....I know the xm is getting power because i installed a power light on the inside. But I dont know if its getting any data transmission.
    -Josh
    1997 Mitsubishi Eclipse GSX
    My URL: https://www.facebook.com/jagray85
    XBOX: DarkerStars
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    It works, do a search for XM and im sure you'll figure it all out. I cant help you as i dont have XM on my pc but i know others here have been using this in FP for a while now.
    I allready did the research. here. I have the XMDirect unit sitting right infront of me. I have the cable made, I've pulled the cable off a few times just to confirm its made right. And still not a damn thing. And its not just frodoplayer, its MMC.
    -Josh
    XBOX: DarkerStars
    Constant Bitrate Troy McClure's Avatar
    I had a similar situation with my car pc and xmdirect. I could not get any software to work with it on Com 1. Out of curiousity I installed it on Com 2 and viola, it worked. I found out that the IRQ used on Com 1 was also the IRQ being used on my Rikaline GPS Virtual Com Port.
    Sounds like an IRQ conflict to me, see if anything else is using IRQ 4, if so, change it.
    Hope this helps......
    Troy
    Done!
    If you're into fishing, checkout my website! http://www.pennsylvaniaanglers.com
    Ok, I only have one serial port. I can change the IRQ's n **** in the bios. And I can change the com port number in Windows Device Manager. I tried changing the com port number, and that didn't work. Uhm....I have the IRQ setting set to Auto in the Bios. There are like 5 settings, None, 3 diff settings, and Auto.
    -Josh
    XBOX: DarkerStars
    Before anything, what do you have attached to your USB ports? if you have a GPS what virtual Com port is it on?
    Done!
  1. XM Equipment CHEAP! XM Direct $29!!!!
    By hevnsnt in forum General Hardware Discussion
    Last Post: 04-11-2006, 10:18 PM
  2. RF Remote Shuts Down XM Radio (Signal Crash?)
    By kbreeden in forum Input Devices
    Last Post: 12-03-2004, 10:38 PM
  3. Sirius vs. XM...? what up Gee?
    By mindscream in forum Car Audio
    Last Post: 10-24-2004, 04:31 PM
  4. Using an XM direct as an XMPCR
    By dacndar in forum General Hardware Discussion
    Last Post: 10-17-2004, 02:21 AM
  5. homebuilt XM receiver
    By stevewm in forum General Hardware Discussion
    Last Post: 07-14-2004, 02:00 PM
