Page 7 of 9 FirstFirst 123456789 LastLast
Results 61 to 70 of 88
Thread: Ls_2.0
  1. #61
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    Thanks Frodo! Great skin LS!
  2. #62
    Hi guys, i've tried 'ing but i can't figure out how to add buttons to your skin..
    Wanted to add a phone button instead of the keyboard button..
    yes i'm stupid!
  3. #63
    Maximum Bitrate clean customs's Avatar
    Jan 2005
    Houston
    My own skin with LS
    I finally finished making the buttons the way I wanted. Took awhile to get back into photoshop, its been awhile. I just reorganized some buttons and took some out that I don't use. Mostly making some bigger. I didn't get into the other things I want to change. Really I only want to make my menu button bigger on the other screens.
    How do you get the numbers to put in the ini files. It tooke me awhile, but I figured it out in a crappy way using the numbers already there and coming up percentages. And then opening it up and using the mouseover to tell me if I got it right. Man you did a nice job in Liquid_smoke, I do appreciate it, and I really appreciate the PSD files. Now I am just looking for an Acura logo.
    thanks again,
    Kenny
    Round VIII - [IIIIIIIIII] 30% Have some parts for 300zx Sema car I don't own yet. Will have 10.4" & 7" screen, and more then you can believe. Will add updates to cleancustoms.com, will be sweet. My car is still same, but might change.
  4. #64
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by frodobaggins
    No.
    Copy them and name them that.
    Both are required.
    Im at work right now, but i just looked in my skins folder at all the skins i have here, and none of them have "picscrollup" or "picscrolldown" even the default skins that come with FP. The do however have "fspicscrolldown".
    I just redownloaded my skin and confirmed that the 2 files are missing but FP gives no errors at all when i load this.
    Also looking at the error message posted above,
    1/22/2005 - 11:00:22 PM - 53 - File not found: 'C:\Program Files\FrodoPlayer\SKINS\LS_2.0_BLUE\PICS\SLIDER\pi cscrollup.gif'
    the file is not named correctly in the error, it has a space after pi
    why isnt anyone else getting these errors?
  5. #65
    Aug 2003
    Chicago
    Quote Originally Posted by tech013
    hey LS this is the best skin that i have used and continue to use
    i like to put my car logo on the background window but i dont know how, i
    have d/l the psd files but i have no idea how to continue, could you help me
    on this ... thanks
    Do you have photoshop? You will need Photoshop to edit the psd files.
    If you dont have Photoshop, you'll have to edit the .jpeg files in the skin folder directly. Let me know which is which and ill tell you where to go from there.
  6. #66
    Aug 2003
    Chicago
    Quote Originally Posted by clean customs
    thanks again,
    Kenny
    I used frodoskinner to get the positions of all the buttons, etc.
  7. #67
    Apr 2003
    HOT Arizona
    LS, I think the space after pi came in when I copy and pasted, I am 90% sure their was no space but I can do it again tonight to be sure.
    BTW, I am so impressed with your willingness to help everyone, it is appreciated!
  8. #68
    Quote Originally Posted by liquid_smoke
    I have photoshop, all help is appreciated!
  9. #69
    May 2004
    Texas
    yes LS i do have photoshop ,i just got it .
    10.5 lcd touchscreen ,shuttle XPC,AMD +2100, 512 DDR, 120 GB drive ,slot dvd,Dashwerks shutdown controller,GPS, XM Direct
  10. #70
    Aug 2003
    Chicago
    ok, basicly in PS you open the psd files
    find whatever logo or graphic you want to add to the skin, and open this in Photoshop also.
    Photoshop works on a layer system. Basicly you create layers and composite images on top of each other and use various methods to make multiple images into one single image.
    For the logo just put this layer on top of every other layer in the skin file, depending on the source of your logo, you may have to delete the background color of it etc.
    Im not at home right now, so i cant really do deep into each step, plus im not sure how much of photoshop you do or dont know, or any graphic experience you may have. But in the mean time, you can look up in the help file photoshop and search for "layers" "select tool" "blending modes" and that should get you well on the way to doing what you want to do. I'll go more in depth when i get home.
