Is everything on one layer? If so then it will be hard to do.Originally Posted by damixt
this is the skin so far.
its nothing good but if you look close you can see that some of thoe botton outlines are a different color. This is my first time with photoshop so i was wondering if there was an easy way to get the color to match each other.
thx
It's the cake having/eating thing.
Select --> Colour Range
Click the colour picker on the black of the background, then slide the tolerance slider until all the background (and none of the button surrounds) are selected.
Click 'OK'
Select --> Inverse
Edit --> Fill --> White
You might have to play about a bit, presuming this is a single-layer image but this is probably the route I'd take if I was unable to redraw it using illustrator/coreldraw or similar
Just as well I'm a graphic designer![]()
Good luck - hope this helps![]()
DC UK Forum
