Page 3 of 31 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 307
Thread: Take 4 Status Report
  1. #21
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    you know if you just use GPS not embedded, and start it before you go into XM then while in XM mode you just switch to minimode you can use GPS while using XM
    肚子笑痛了
    S60 Install
  2. #22
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    I would like to see the new XM be able to continue running while you switch to radiator or mp3, just stop the audio. I like to switch back and forth between FM, XM, and MP3. The current XM module takes a while to start up and generate the station list. If it worked kinda like the GPS did, where you can hide it, that would be cool.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
  3. #23
    Jul 2004
    NL, Druten
    Frodo, i was wondering if it's possible to add some flash in the screens.
    All the screens are pretty simple right now.. just need more flashing screens, backgrounds and menus..
    this is for inspiration:
    http://www.2advanced.com/flashindex.htm
  4. #24
    Nov 2004
    Quote Originally Posted by TheKingPlaza
    Drive Much?
  5. #25
    Nov 2004
    There are a few things I would like to see...
    1. Volume slider
    2. Having playlists and all music in the same space (being able to switch between
    the two)
    3. A good guide on skinning
    4. EQ built in with presets like the nforce mixer
    IS that asking too much?
  6. #26
    Variable Bitrate kiztope's Avatar
    Nov 2002
    In the car
    neat
  7. #27
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    joy.. here comes take 4 and i'm just gettin used to take 3 :P
  8. #28
    Jan 2004
    I just can't wait for XM.
  9. #29
    Jan 2003
    Ruston, LA
    You guys gotta remember, this is Take 4 of 1.09, not 1.10
    Don't expect the wheel to be reinvented.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  10. #30
    Low Bitrate Bigassbike's Avatar
    Oct 2004
    On the computer
    You da man!
    Thanks for all the hard work!
    Planar 12.1TS
    Xenarc 700TS
    Xenarc MP-SC8 Mini P4 Aluminum Car PC
    Sound Blaster® Audigy® 2 NX
    2.8 Celeron D
    512 PC2700
    Dual Odyssey 1200s for Power
  1. FP 1.09 Status Report
    By frodobaggins in forum FrodoPlayer
    Last Post: 01-29-2006, 05:19 PM
  2. LED Battery Status (assembled)
    By OriginalNick2 in forum General Hardware Discussion
    Last Post: 11-06-2004, 02:20 PM
  3. NMC 07 development status
    By netsuo in forum NeoCar Media Center
    Last Post: 11-03-2004, 04:18 AM
  4. Bad Post Report
    By SjLucky in forum Mp3car Forum Suggestions/Comments
    Last Post: 07-02-2004, 04:38 AM
  5. Update on MediaEngine status...
    By CarComp in forum ME Archive
    Last Post: 12-02-2003, 12:59 AM
