Results 1 to 10 of 10
Thread: Help! Configuring Radiator with MSI Card
    Newbie Focus's Avatar
    Jan 2005
    OK here is my problem. I want to get radiator working with frodopalyer but for the life of me, I can't figure out the driver I need to use. The chipset is the conexant CX2388x series.
    Here are some of the cards that use this chipset, if this helps any. :
    (Mine is the MSI TV@anywhere master)
    TV Cards with Conexant CX2388x Chipset
    ATI TV Wonder Series YES
    AverMedia TV Studio 303 YES
    MSI TV@nywhere YES
    PixelView Play TV HD PV-CX881PL+ NICAM YES
    Hauppauge WinTV Go2 YES
    Hauppauge WinTV Primio FM YES
    Leadtek Winfast DV 2000 YES
    Leadtek Winfast TV 2000 XP Expert YES
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    Tell us what you have tried so far. You selected the appropriate card in the settings? You have it working with its own software?
    Jan 2005
    Quote Originally Posted by ddogg_777
    Yes it works with it's own software. I have tried all of the built in cards and no luck with radiator.
    Apr 2003
    HOT Arizona
    Well, here is one thing: When radiator is open double check your volume settings to make sure none of them are muted. This sounds stupidly easy but it had me confused for days when I first tried to get my card working. It turns out that my OEM software was muting the line on exit. Radiator was working fine, I just didn't know it...
    Dec 2004
    CT
    Try Something of this sort
    Im goin to have the same problem when i hook up my card(building carputer case at the moment), when i was having problems with the card in linux i followed a guide for the bt878 and i got it oworking so mabe this migt help How to make your bt878 or other radio/tv tuner work with Radiator
    i dont know, if anyone else got this working please post info on how to.
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    Quote Originally Posted by bobs987
    Wow someone referenced my post. Cool. The only problem is that the MSI does not use a BT878. I actually tried it this weekend and the btspy would not recognize the card at all. I don't think it's possible. Sorry to tell you. Has anyone gotten this card to work with Radiator???
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Dec 2004
    CT
    what kind of card do you have, is it the TV @nywhere??, has anybody had luck with this?
    its driving me insain
    Jan 2005
    Yes the Tv@nywhere Master card from MSI
    Dec 2004
    CT
    Quote Originally Posted by Focus
    what kind of setup do you have, how did you get it it work??? Details please thanks
    Jan 2005
    I didn't get it to work with Radiator yet, just with the MSI Radio.
  1. Ewww sound card + video card on dual pci mini-itx reiser card = audio interference
    By psyclobe in forum Software & Software Development
    Last Post: 01-23-2008, 02:59 AM
  2. XP Pro on CF card working!!
    By knubile in forum WinNT Based
    Last Post: 01-03-2005, 07:48 PM
  3. FS ATI Technology R360 graphic card
    By l4tran in forum Classified Archive
    Last Post: 08-14-2004, 10:37 AM
  4. need PCI nvidia video card with Conexant TV chip
    By Onyx in forum General Hardware Discussion
    Last Post: 11-12-2003, 04:14 PM
  5. help - video card problems
    By Cliff in forum General Hardware Discussion
    Last Post: 04-15-2002, 06:25 PM
