Results 1 to 10 of 18
Thread: Can't shutdown in Frodoplayer but can if I exit out of it
    Oct 2004
    I get that error "It is now safe to turn off your computer" when I shutdown from Frodoplayer. If I exit out of Frodoplayer and then shutdown then it does so just fine. Is it some kind of driver issue or am I just missing a setting here in Frodo?
    Thanks!
    Jan 2003
    Ruston, LA
    I've only seen that one other time, and I don't know how to fix it.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    Since a lot of us use Frodoplayer and I havent heard of this issue yet, try this:
    Use Task Manager to determine the programs that are currently running on the computer. Manually quit each program that is listed in Task Manager (besides Frodoplayer), and then try to shut down and restart the computer to test if the shutdown problem is resolved. To do this, follow these steps:
    a. Press CTRL+ALT+DELETE, and then click Task Manager.
    b. Click the Applications tab.
    c. In the Task column, click the program that you want to quit, and then click End Task.
    d. Quit Task Manager.
    e. Shut down the computer.
    Hopefully you can narrow it down to a program that is running along with Frodoplayer. They also say it could be a driver issue, but I dont see how if it shuts down normally when Frodoplayer is down.
    2005 Ford Focus ST
    Jan 2003
    Ruston, LA
    Also, what OS are you using ?
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Dec 2004
    Yeah, I had investigated quite a bit on this issue before I posted here. I'm using Windows XP Pro. I did the task manager trick and thats how I determined it was FrodoPlayer that was not allowing me to shutdown. I only have 2 applications installed on the laptop and thats Frodoplayer and WinDVD. It could be a driver issue but you're right, I'd suspect that would be an issue if I couldnt shut down at all, but this just happens in Frodoplayer.
    Constant Bitrate shiltz's Avatar
    Dec 2004
    Massachusetts
    I started having that issue last night too, had had to reinstall windows on my computer and now when I try and shut down in frodoplayer it doesn't fully shut down it comes up with the it's now safe to shut off your computer message, before I reinstalled it shut down fine though, also using XP pro.
    Jan 2005
    Something similar started happening to me too...i can shut down fine if i use the start menu...even while frodoplayer is running. But if i shutdown from frodoplayer it says shutting down...saving settings...and then my screen goes blank, but the pc is still running. If i hit the power button the pc then shuts down fully. Funny thing is it did actually shut down from frodoplayer once in the ten times i tested it.
    Dec 2004
    Yeah, I don't have any options in the BIOS for power management or an ACM tab in the Power Management. I've looked over some Microsoft pages and have come up to no avail. Something in Frodo is impeding me to shutdown. I'll continue to investigate and hopefully something comes up.
    Maximum Bitrate EBFoxbat's Avatar
    Jun 2004
    Massachusetts
    I didn't know WinXP had the "It's now safe to shut off your computer" message.
    ,./(0)3
    '04 Canyon 4x4 pickup
    [---PC on hold----working on external fiberglass "tool" box---]
    Bowel movement jjh221's Avatar
    Dec 2003
    not sure yet.
    my pentium2 has xp and says its now safe to turn of computer. I dont know if its the mobo or its because it has only a push button switch.
    I GIVE FREE HUGS!
    Buy Sell or Trade
    If my pm box is full, please feel free to call me any time. 440-328-3382
    Thank you
    Forex
    Rate Mp3car @ FXroot.com
  1. cant change skins???
    By Hell-Stopper in forum FrodoPlayer
    Last Post: 11-05-2004, 11:10 PM
  2. Bug Reports 1.09
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-22-2004, 11:24 PM
  3. Bug Reports
    Last Post: 10-16-2004, 01:25 AM
  4. Frodoplayer - Audiobooks & OBD-2?
    By fbruno in forum FrodoPlayer
    Last Post: 05-04-2004, 09:51 PM
  5. New Improved ATX Shutdown Unit!
    By Danceheaven in forum General Hardware Discussion
    Last Post: 04-15-2004, 10:52 PM
