Originally Posted by n8scstm
what did you do to get it working?... so far i could only get AVI files to show up on both screens....
I finally got both screens to play video in WMP by changing some settings for the video card. It works in WMP but I still can't get it to work in FP. Has anyone had a similar problem and maybe a solution?
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
8" Lilliput touch screen
IGuidance
dual optimas
battery isolator
15" screen
My Truck
what video card are you using?
I know you can do this with nvidia based cards and possibly ATI. with nvidia cards it uses video overlay to detect when your playing a video and then display it on multiple screens.
Ati is the same way. It also uses overlays. I have the ati 7000. To get it working, I only enabled one monitor in windows. Double click the monnitor that you enabled and that should bring up the ATI properties. Click on "Displays" and turn on your secondary monitor by clicking the little power icon. Set one as primary and one as clone. Doesnt matter which. Then click on the "overlay" tab and select theatre settings or something like that. Then click "same on both" That works for WMP but now im not getting video in FP on either monitor.
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
IGuidance
dual optimas
battery isolator
15" screen
My Truck
So it works for you now?
2.4 celeron
150 watt OPUS
micro atx
xp pro
tv/radio tuner card
audigy
Dual monitor Radeon
802.11G Mimo
xm pcr
dvd
gps
IGuidance
dual optimas
battery isolator
15" screen
My Truck
yeah i had it working... I only have 1 screen plugged in there right now though...
I'll go through the settings and make notes next time... then I will post the steps here
great thanksI tried a lot of things, including outside programs such as Unltra mon, and I got to clone everything except DVD. and I played around with settings for the card, and dvd playback...but it still obeys the overlay setting (either crt or composite...not both
) hopeful you got dvd working
Diceman
DICE Los Angeles
Thats how matrox g400 based cards do it, esp the marvel with the tuner etc.Originally Posted by liquid_smoke
Matrox(marvel) are _flawless_ at this trick.
With most nvidia chipsets they will pop up the video fullscreen on monitor2(tv out) but if you then start clicking things and opening shutting windows on monitor1(vga) then the 2nd output loses fullscreen or stops.
Just try to fullscreen/minimise/shrink/resize WMP on screen1 and see what happpens on screen2
None of that with a matrox.
