Results 1 to 10 of 17
Thread: Embedding Destinator and Frodo question
    Hey, finally got Destinator 3 working.. tried it with Frodoplayer and it works great. only one problem, there is no way for me to track ahead to the next or previous song while the GPS screen is up like i can when running Iguidance within Frodo. when i use iguidance, i can be using Navigation and still track ahead while im listening to music..
    any help would be appreciated,
    Craig
    Jan 2003
    Ruston, LA
    Map Monkey takes care of that for you, that's why the controls aren't on there.
    Look in the Map Monkey forum for how to configure it to control FrodoPlayer.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Frodo,
    i am using Map Monkey.. did you think i wasnt using Map Monkey and were saying to use it or are you saying i don't have Map Monkey configured properly to control FrodoPlayer? thanks for your response, Frodo.
    Craig
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Craig W
    Frodo,
    Craig
    Translation: its not properly configured.
    Quote Originally Posted by 0l33l
    thanks for the responce! your up next cus nav voice is next on my list
    where do i configure map monkey to track ahead and pause/play?
    Craig
    Jul 2004
    Berkeley, CA
    Craig
    Thanks... I hope I can get map monkey working with NaviVoice.
    To get map monkey to play with Frodo go to "C:\DestinatorApps" and select "Destinator 3 Frontend - Configuration". Then under the environment tab select FrodoPlayer.
    i wonder if im using the wrong version of Map Monkey as i have no environment tab. i just grabbed the d3fullpackage1.1 then did the 1.3 hotfix. am i missing something?
    Craig
    ps. thanks for your help.
    Jul 2004
    Berkeley, CA
    Craig
    Well, this is in 1.1.3 BETA. The tab is "Environmen" because the T got cut off on my screen. There is a drop down box under "Map the embedded media controls to".. that's were you select FP.
    i don't have that tab anywhere. would i be running beta 1.1.3 beta if i installed the full version, then did the hotfix 3? when i load it up and go to about, it says MapMonkey 'D3 FrontEnd V1'
    Craig
    Jul 2004
    Berkeley, CA
    Craig
    UGPM
