so no answer for this????
anyone?
How did you guys even get it to load? Map monkey (release ver) is renamed to mapmonkey.exe and destinator3.exe is no longer there. So I made the changes to the ini file GPS_EXTERNAL=FALSE
GPS_APP_PATH=C:\destinatorApps\Map Monkey\MapMonkey.exe
GPS_APP_CLO=NONE
GPS_EXTERNALPAUSE=FALSE
GPS_MINI=FALSE
And when press GPS it just blinks and goes back to the menu. No mapmonkey comes up.
Anybody get the new launcher to work with Frodo?
I must be doing something wrong. I’m calling the launcher via the “frodoplayer.ini” and it’s launching correctly, however the “Title-bar” issue is still there. Not only that but now when I exit Map-Monkey the launcher window remains present…
Anybody with similar results?![]()
I have the opposite problem. I can see the top 'currently playing' bar while using GPS, but I've never been able to see the bottome 'player controls' while in GPS.
I think you’re all set. That’s proper operation for Map-Monkey. You can control the currently playing selection via the top << and >> buttons.
Where did you place the "MapMonkeyLauncher.exe” file?
I placed mapmonkeylauncher.exe in c:\destinatorapps\map monkey\mapmonkeylauncher.exe
edited the frodoplayer.ini file to that path
lauch gps button in frodo player and map monkey is not embeded.
I've done the same.Originally Posted by mpfjr
Although the title bar of Map Monkey is changed in to "Destinator 3 - [Dest3.1]" now, Frodoplayer isn't able to embed Map Monkey :-(
Map Monkey now just lays over Frodoplayer...
yup, ditto... seems like map monkey no longer "embeds", perhaps frodo needs to re-implement that since it looks like map monkey went thru a major code overhaul which caused this.
'05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
