Results 1 to 10 of 12
Thread: How to disable the description label???
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Question How to disable the tooltips in frodoplayer
    Hey Frodo I got a question for you.........
    How to disable the white label??
    when you touch the bottons with the mouse pointer it display the description of what the botton does...(menu,volume,mute etc)......I see no reason to have this displaying what the botton is for when you have it onthe big botton itself!!
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Good question. I believe those are known as ToolTips.
    They also appear on touchscreens. Even with the mouse turned off, Windows knows its position and displays them.
    They can be useful, like when using an unfamiliar skin, but most of the time I'd like them turned off...
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
    May 2004
    Open up explorer, click Tools - Folder Options then click the View tab. Uncheck the "Show pop-up description... " option. I believe this should do the trick.
    Nov 2004
    thanks!
    May 2004
    I thought about this more in the morning and I realized that this doesn't fix the problem. It prevents the files and folders from poppup up a tooltip but the tooltips in FP still pop up on the buttons. Maybe the buttons are programmed in FP to show windows tooltips?
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    there was some discussion about this a while back... and as current there is no way to completely turn off tool tips in windows... Frodo i believe still has this on his research list
    May 2004
    I read there is something about using TweakXP to make the tooltips transparent but I don't get that bugged by it. What bugs me more is having a mouse pointer after coming back from hibernation!!!
    Nov 2004
    Yeahhhhh Those Tolltips Drive Me Nuts....
    Newbie halve85's Avatar
    Feb 2005
    this i have found (but it describes Mac... is it the same in Windows??!)
    http://forums.macosxhints.com/archiv...p/t-28018.html
    "I thought tooltips like that were based upon the application, and not the OS?"
    "Indeed, tooltips are application-specific. The application developer has to choose to use tooltips or not, and to decide what text should appear for each item. Some applications have a preference item to disable tooltips."
    so far...
    Frodo is that right? Then plz disable these Tooltips
    Nov 2004
    Yeahhhhhhhhhhhhhhhhhhhh!!!!!
  1. Super small XP install
    By knubile in forum WinNT Based
    Last Post: 04-26-2008, 02:44 PM
  2. nLite and USB Devices
    By Nobias in forum WinNT Based
    Last Post: 01-20-2005, 10:11 PM
  3. nLite making me nSane: Frodoplayer issue
    Last Post: 01-13-2005, 12:09 AM
  4. How to disable that WinMe message?
    By Dimitris1976 in forum Software & Software Development
    Last Post: 04-29-2002, 06:55 AM
  5. How to disable Win98 safe mode menu?
    By Phacade GSX in forum Software & Software Development
    Last Post: 04-30-2000, 11:43 AM
