Results 1 to 4 of 4
Thread: Skins look "grainy" with Adv screen settings OFF
    Variable Bitrate The Grinch's Avatar
    Jun 2004
    Toronto, Canada
    In order to get Frodo Player to center properly on my setup, I have to turn the Advanced Screen setting to OFF. But I've noticed that the quality of the skin goes down the drain. It's all grainy looking, like anti-alias is off or it's displaying in 256 colors. Text looks normal though. I've tried the default and a couple other downloaded skins with equal results. Is there a way to improve the skin quality?
    Carputer progress meter: [-----|]
    Carputer gadget meter: [--|---]
    Jan 2003
    Ruston, LA
    What res are you using and what res was the skin designed for ?
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Jun 2004
    Toronto, Canada
    Ya know.... I hadn't even thought about that. I've been doing some testing on a desktop in 800x600. I think I'm starting to see the light. I'll try an 800x600 skin. Thanks.
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    also if you just want to center the skin on screen, and turning off advanced screen settings makes it center, it sounds to me the values in the frodoplayer.ini file are not centered. Its a quick fix, just open froodoplayer.ini and find this section at the bottom
    Code:
    [ADVANCED]
    ADV_TOP=0
    ADV_LEFT=0
    ADV_WIDTH=800
    ADV_HEIGHT=600
    make sure in your file ADV_TOP=0 and ADV_LEFT=0
    set the width and height to whatever screen res your monitor is set to.
    Should fix your problem.
  1. X-MP3Pad: Beta testers needed... Please read!
    By PorscheMP3 in forum Software & Software Development
    Last Post: 08-22-2002, 11:55 AM
  2. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 02:16 AM
  3. Replies: 13
    Last Post: 07-02-2002, 10:54 AM
  4. screen help
    By XCURSN in forum LCD/Display
    Last Post: 06-24-2002, 11:10 AM
  5. NEC Versa M/75 Laptop TFT screen w/touch
    By Macgyver777 in forum LCD/Display
    Last Post: 03-24-2002, 02:14 AM
