Page 1 of 8 12345678 LastLast
Results 1 to 10 of 78
Thread: [SAT RADIO] Alpha 2
    Jan 2003
    Ruston, LA
    [SAT RADIO] Alpha 2
    Here is Alpha 2 of FrodoSatelliteRadioX.
    You need to edit the FrodoSatRadX.ini file before use.
    Should be self explanatory.
    FrodoSatelliteRadioXAlpha2.exe
    Have Fun guys.
    Frodo
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Jan 2003
    Ruston, LA
    For you embedders
    Window title is "FrodoSatelliteRadioX"
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Constant Bitrate Prindle19's Avatar
    Dec 2004
    Jersey/Virginia Tech
    WOOHOOOO will test ASAP THANKS BUDDY!
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    nice!, shame I have to wait till I get home to try it.
    肚子笑痛了
    S60 Install
    Dec 2004
    Alright, I was late to work, but i got this version embedded into Centrafuse, and it works great! The application now perfectly resumes to the station you were listening to before hibernation, and the favorites buttons can be set by simply changing to a channel, and holding down the button you'd like to set for 3 seconds!
    (Thanks for the High Voltage graphic)
    My next step is to find out what size the window is that Centrafuse uses so that i can make a skin to fit inside that little window.
    I realize FPSRX does not actively resize, so it may be a bit of a pain to utilize centrafuse's "Fullscreen" mode when you tap on the centrafuse header in the radio module.
    Ideally though, i can control volume and everything through centrafuse, so what i would like to do is just get all my favorites buttons to fit within the normal mode Centrafuse window, along with the station information and channel windows from FPSRX.
    The grid isn't all that important to me, since i usually stick to my main favorites, but i guess it would be nice to have some way to see three lines or so of the grid...
    Any "tips" for sending me on my way to skinning for this purpose?? Are the values in the skin.ini simply pixels?
    Also, i think i'm missing the point of "secondary" favorites.....how do you use these?
    Dec 2004
    Ok, thought about this.
    Main window in Centrafuse will show:
    Channel - Station Info - Station Logo
    12 Favorite Buttons.
    Then, when we click on the Centrafuse header to expand, it will show a small grid, probably only one or two lines, and the scroll bars i guess.
    Here is where an alternative way of tuning channels (popup keybad, etc) would be nice.
    Here's a simple idea i have in mind for how to implement this.
    Once i get the dimensions from the Centrafuse forum, i'll make a quick and dirty skin for centrafuse use. And yes, it will be green. Sorry, gotta match my Eddie Bauer Centrafuse skin.
    Inside Centrafuse
    When Fullscreen Enabled
    *Course things will be better centered once i do it for real.
    Dec 2004
    Doh, not pixels, but rather percentages.....damn thats gonna take me longer!
    Jan 2003
    Ruston, LA
    It will resize, it just has a slight delay. Which could interfere with resizing at start, but
    that can be fixed by having it open at the right size.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Dec 2004
    Here's a test skin i made, not complete, but it works to embed!
    FSRX CENTRAFUSE
    Set your Application window size in the main Frodo Satellite..... config.ini to 800x520
    Now, how can i change the colors of the "playlist"
    Im not sure how to convert from RGB or HEX to component.
    Maximum Bitrate R32 JUhl's Avatar
    Nov 2004
    North Atlanta
    Frodo, installed it! On a shut-down and restart of the software, it ACTED like it was returning to the last station listened to, it showed that station in the window, but it actually retuned to the Preview Channel. I tried it again on a full reboot and it behaved in the exact same manner.
    Now, I did not uninstall alpha 1 before installing alpha 2. Advice?
    This software !@#$ing rocks!!! I think Prindle wants to have your children!
    My first attempt at a carputer.
    PM me if you're interested in a monitor faceplate for your '99-'04 Golf or Jetta. My Vortex ID is NorthAtlR32 - you can IM me there, too. Go here for more information.
  1. [Release] FrodoSatelliteRadioX Alpha 1
    By frodobaggins in forum FrodoPlayer
    Last Post: 02-03-2005, 08:42 PM
  2. Alpha 2a is out, skinners i need you
    By netsuo in forum NeoCar Media Center
    Last Post: 12-24-2004, 02:57 AM
  3. Big bug found on Alpha 2 !
    Last Post: 12-15-2004, 06:28 PM
