click the actual textboxes, you'll find you have modifier keys set up
The keyboard shortcuts dont do anything for me.
I never noticed it wasn't working until I plugged in my Griffen PowerMate. I can have the PowerMate send keystrokes to control Frodo, but Frodo doesn't even recognize keystrokes when I attach a keyboard.
I also have frodoplayer installed on my laptop (which I am using now) and the keyboard shortcuts dont work here, either. Well, I guess to be fair I haven't done extensive testing in the car, but the laptop frodoplayer doesn't do it, so I'm assuming there is a setting somewhere that I have to set and it will work. I've tried looking through the settings options but cant find it anywhere! Am I missing something obvious?
Thanks all!
[H]4 Life
I'm a lesbian too.
I am for hire!
i was looking at that as well... is there anyway to set it up so that i don't have to hit any modifier keys?
for instance... just hit "b" on the keyboard for next track/song
none of my modifier keys are checked... so i'm not sure if it works that way or not
If they're not checked, it ought to work when you hit that key. No modifier necessary.Originally Posted by ummagawd
Want to:
i actually just tried it using a modifier (checked shift) and when i hit shift and the corresponding letter... it doesn't do anything? .... weird
I've had that behavior on a couple of keys too but never bothered to figure it out. I just changed the key and it worked with that one.
Want to:
