Page 17 of 20 FirstFirst ... 7891011121314151617181920 LastLast
Results 161 to 170 of 195
Thread: *Release*[SAT RADIO] Alpha 3
  1. #161
    Apr 2005
    Is there a way to make short cut keys like the frodoplayer/settings1/key shortcuts? What I want to do at a minimum is use my spacebar to toggle through my favorites ....
    Car-mada-puter Epia MII12000, 40gig HD, 512mb ram, Morex 3688 case, M1-atx and XP Pro.
  2. #162
    Variable Bitrate kmcniece's Avatar
    Aug 2004
    Portland, Oregon
    I have been using the old XM app till today.... I thought I would try out the new one since I had it on board. A few questions though....
    TO set the Preset buttons, I used to be able to hold the button and it would set it to the currently playing station. Now it seems to only change the channel. Is there any way of changing my presets from the front-end vs. editing the INI files?
    I was getting some periodic snaps, crackles, and pops in the background... I think it has somethingto do with the EQ feature. I muted the WAVE line and it seems to have stopped... The Line-in is not muted either. In effect, have I bypassed the EQ feature by doing this?
    One other thing thatseems to be a little bothersome.... they keep playing Linkin Park on Squizz..... that kinda irks me....
    Otherwise.... Thank you for a great program. I truly appreciate it.....
    EPIA M10000, 512 Ram, Opus 90, GPS, XM, 7" Xenarc, Pioneer HU
    Status:
    Installed & Working....
    Custom enclosures
    Newbie Guide
  3. #163
    May 2004
    I just installed FP and FPSatelliteRadioX for my XMD1000 unit. I set up application1 to point to the FPSatRadioX application and everything seems to be working fine. However, two questions:
    1- Is there a way to mute the music from the Media when I click on XM Radio in the Menu?
    2- When the FPSatRadioX application loads after I hit XM Radio, it comes but how to I go back to FP? I tried hitting Exit and that works however the process for FPSatRadioX still is running. I can't get back into it by hitting XM Radio from the Menu again. What's the best way to switch between these applications?
    BTW, I'm using the BrightLife skin.
  4. #164
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    1. you have to setup APP1PAUSE=TRUE in FP .ini file.
    2.I don't use XM radio but this is my advice (until big monkey comes)
    You can make this changes in FrodoSatRadX.ini
    [SIZE]
    FULLSCREEN=FALSE
    MOVELOCKED=FALSE
    ;In Pixels:
    APP_LEFT=0
    APP_TOP=46
    APP_WIDTH=800
    APP_HEIGHT=554
    Leaving you with a gap on top so then you can use setup FP task future.I see a hide button but it doesn't do anything (maybe cus I don't a XM unit?)this will be the way best way to switch between APPS but if you use this way how you shut the sound in XM so you can come back to listen to the player??....well I don't know just a thought in how to switch APP.
    Also when testing I notice that the APP still running after hiting the close button, but this was fix when I open FP to take this shots.(maybe that is you problem) or maybe is a bug in the APP.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
  5. #165
    May 2004
    Quote Originally Posted by thanatos106
    Thanks! This was a good fix except for one issue. When I hit the top part of the screen to return from XM to FP, the only way back is like you said.. to switch between the application list and pick the XM app. However the only problem is that now I get a Mini Mode bar at the top instead of the XM app on top of FP. I set both App1Mini = false and XMminimode = false in the ini file for FP. Thought?
  6. #166
    Nov 2004
    Quote Originally Posted by tmar89
    you need to set MINIMODEONTASKSWITCH=FALSE in FP .ni file
    Thanatos.
    Nissan Aux-in MOD
  7. #167
    May 2004
    Thanatos.
    That worked like a charm! Thanks!
  8. #168
    Nov 2004
    Cool.... glad to hear that
    Thantos.
    Nissan Aux-in MOD
  9. #169
    Low Bitrate IonDokk's Avatar
    Michigan
    I get a 404 error when I try this link would really like this update! Thanx
    Epia M1000 1.2gig, Toshiba 40gb HD, Itronix 60gb HD, 512ram,PCR, Audigy2zs, 2 Xenarc 7" , FRODOPLAYER Trying RR frontend , 2@1600/w Harrison labs amps & Caps, Focal & MB-Quart midrange, Diamond Audio D6 Subs, Mb Quart Tweets, 2-Audiocontrol three.1 !
  10. #170
    Aug 2004
    Portland, Oregon
    Status:
    Custom enclosures
    Newbie Guide
  1. [SAT RADIO] Alpha 2
    By frodobaggins in forum FrodoPlayer
    Last Post: 05-04-2005, 09:13 AM
  2. Alpha 2a is out, skinners i need you
    By netsuo in forum NeoCar Media Center
    Last Post: 12-24-2004, 01:57 AM
  3. MapPoint Embedded Alpha Testing Results
    By antimatter in forum Software & Software Development
    Last Post: 04-01-2004, 03:16 PM
