Frodo, great app I love it!
One minor cosmetic thing that I noticed. The volume level (%) doesn't change when you hit + or - until you mute and unmute, then the new level will show up.
Keep up the good work - my donation is on it's way!![]()
GRod
Few bugs fixed (don't ask, I don't remember)Originally Posted by MoFo
Minimize button (not on skin, look in the ini)
Save info button(not on skin, look in the ini)
---Also you can just click the big channel number to do the same thing.
I don't know right now if anything else made it in.
Gotta go get my espresso ! Maybe it'll jog my memory.
Frodo
[H]4 Life
I'm a lesbian too.
I am for hire!
GRod
Carputer/AV System ~95% complete
Parts all acquired - testing underway
Fabrication and integration underway
More on my Ride
Huh. I sure will check it out.Originally Posted by GRod
[H]4 Life
I'm a lesbian too.
I am for hire!
Wait! So now I have the record device set to Microphone (for voice recognition) and my Mic playback muted. My XM comes in via SPDIF-In. So I need to mute that and set the recorder to SPDIF? How does the mic work then since I can only have one device enabled on the recorder side???Originally Posted by frodobaggins
Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
still doesnt play nicely with centrafuse after hibernation![]()
Any possibility to add a button that you could click to force a reconnection to the directxm, so we could just do it manually?
It doesn't, it's the price you gotta payOriginally Posted by wysocki
[H]4 Life
I'm a lesbian too.
I am for hire!
The config allows me to mute the master, wave, cd, line inputs. Any provision to mute the SPDIF input? This would also apply to the full Suite product.
Good times. Eventually I'll get off my *** and make a skin so I can use this puppy.
'02 GTI
[Routis '04] [Opus 90W] [160GB Maxtor HD]
[Lilliput 7" TS] [VIA M10000] [XMPCR]
[512MB RAM] [Custom housing]
[Deluo GPS Mouse] [E-MU 0404 Soundcard]
Progress Meter: [==============|] 99.9%
I was tweaking a skin and when I went to use it, there were no hidden channels listed on the favorites screen. I just tweaked the main screen and used the bluedefault800x600 favmenu image. There are a bunch of stations in my HiddenChannels.txt file and I don't see them on the main screen but they just don't show up on the favorites menu.![]()
I guess I'm slow...
To get the eq working properly..
If I have my XMD coming in on "Line in" - do I need to mute the line in the playback side?
