now how in the heck did I miss this....
Yes. Mute the line in on the playback side,Originally Posted by eleventh
and make sure line in is selected for recording.
[H]4 Life
I'm a lesbian too.
I am for hire!
肚子笑痛了
S60 Install
Still need to play with the EQ.. but in the meantime..
I'm not sure if this has been suggested before, but since you can hold the preset buttons to set them, could you add a little "blip" sound once it has been set, like some head units do?
Sure.Originally Posted by tj!2k4
[H]4 Life
I'm a lesbian too.
I am for hire!
Especially when I told you I was about to release it on IM...Originally Posted by jcdillin
[H]4 Life
I'm a lesbian too.
I am for hire!
Cool.. =)Originally Posted by frodobaggins
Without being too much of a pain in the ***, it might also be useful to have a numeric keypad to punch in a channel manually.
Also, I noticed that clicking the channel # writes the currently playing song info to XMSavedSongInfo.txt.... Sweeeeet!! =)
I must have closed that IM by accident![]()
anyhoo, great job. works wonders
love the eq
肚子笑痛了
S60 Install
DAMN! I'd love to be able to take advantage of the new EQ but I'm running Navivoice for my voice processing and need the mic-in as the recording source. I'm working on setting up a hardware button that will cause the pc to mute/pause audio output and enable mic-in for voice commands. Maybe this can be integrated somehow...
BTW Frodo, how much CPU does the eq take?
Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
Don't you also have line in or something?? You can change the mic source in SAPI properties BTW.Originally Posted by wysocki
I did notice that when i use the equaliser and i started to turn some of the sliders up a bit.. I would get distortion even at a low volume....
but with the qualiser turned off.. this thing rocks...
