Page 7 of 20 FirstFirst 1234567891011121314151617 ... LastLast
Results 61 to 70 of 195
Thread: *Release*[SAT RADIO] Alpha 3
  1. #61
    Raw Wave tj!2k4's Avatar
    Oct 2004
    sounds good, will give it a shot, thanks =)
  2. #62
    Low Bitrate GRod's Avatar
    Aug 2003
    San Diego
    Can't get SAT RADIO to load
    I keep getting the following error message 'Component 'MSCOMCTL.OCX' or one of its dependencies not correctly registered: a file is missing or invalid"
    I've downloaded the Alpha 3 version and reloaded it onto my PC a number of times, but still get the same message. I can get XMPCR to work no problem, but not the Frodo XM Sat Radio application - any ideas where to look?
    Thanks,
    GRod
    Carputer/AV System ~95% complete
    Parts all acquired - testing underway
    Fabrication and integration underway
    More on my Ride
  3. #63
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by GRod
    Thanks,
    GRod
    Reinstall the VB runtimes.
  4. #64
    Aug 2003
    San Diego
    Ok, this will be a totally noob question, where do I get the VB runtimes?
    More on my Ride
  5. #65
    Jul 2004
    Berkeley, CA
    http://www.microsoft.com/downloads/d...displaylang=en
  6. #66
    Aug 2003
    San Diego
    Quote Originally Posted by 0l33l
    I reinstalled VB runtimes and got the same error message - is there a debug script that I can run that would tell me what is missing?
    thanks,
    GRod
    More on my Ride
  7. #67
    Low Bitrate Erorus's Avatar
    Feb 2005
    NEPA
    grod: you need MSCOMCTL.OCX. google for it, download it, put it into \winnt\system32
  8. #68
    Aug 2003
    San Diego
    Fixed!!
    Quote Originally Posted by Erorus
    Thanks, MajorGeeks described exactly the problem I was having. The link is as follows: http://www.majorgeeks.com/faqshow.php?id=8
    Component MSCOMCTL.OCX or one of its dependencies not currently registered ...
    Here's what I got from MajorGeeks - and it worked perfectly!
    GRod
    Sometime certain Microsoft Libraries can become unregistered when installing and uninstalling a lot of software. One very common problem is the MSCOMCTL.OCX.
    To correct the error, first search your drive for MSCOMCTL.OCX to see if you have it. If not you can download it from HERE
    The file should be placed in your C:\WINDOWS\SYSTEM directory.
    Once it is there click START--> RUN and type "REGSVR32 MSCOMCTL.OCX" (No quotes) in the box.
    That should fix the problem.
    More on my Ride
  9. #69
    Jan 2003
    Ruston, LA
    For those of you having problems with the row sizing only
    Try this out at your own risk
    FSRX Patch Test 1 Setup
    Tell me if it works !!!
    Frodo
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  10. #70
    Maximum Bitrate wysocki's Avatar
    Mar 2004
    Los Angeles Area
    That fixed it! Thanx! But what's going on here? Although my player is in c:\program files\frodosatradiox, it installed a folder c:\program files\frodosuite\patch that contains just two files: unins000.dat and unins000.exe. Do I just leave these there or what?
    Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
  1. [SAT RADIO] Alpha 2
    By frodobaggins in forum FrodoPlayer
    Last Post: 05-04-2005, 10:13 AM
  2. Alpha 2a is out, skinners i need you
    By netsuo in forum NeoCar Media Center
    Last Post: 12-24-2004, 02:57 AM
  3. MapPoint Embedded Alpha Testing Results
    By antimatter in forum Software & Software Development
    Last Post: 04-01-2004, 04:16 PM
