You da monkey!
Doesn't matter. It did fix the list problem ????Originally Posted by wysocki
Right ?
[H]4 Life
I'm a lesbian too.
I am for hire!
You da monkey!
Epia-M II M10000 Nehemiah WinXP sp2 Travla C134 case Carnetix 1260 power Xenarc 700TS XM Direct Toslink Extigy USB 5.1 Garmin GPS18 Linksys 802.11g wireless Nokia 6230 Bluetooth Memphis Amps Focal Speakers Frontend: RoadRunner
I just bought the XMD100 and all the setups from someoen on the forums. I have the antennae, and a serial connector to my computer. I also have two rca outputs running to the Line IN of my computer. So, I have everything connected, and I have the XMD getting power, I think (there are no LED lights to show power, but I haver it connected right), and everything is connected perfectly. I go to the Sound settings in my lower right corner, and here are the options:
Volume Control
Wave
SW Synth
SPDIF
Aux
CD Player
Line In - MUTE
Microphone
All are set to around 50% except the Line in has the Mute checked. I tried disabling the EQ in the ini file, but still no luck. At first, I was getting static, but I messed around a little and am getting no sound whatsoever from the software. It won't receive any channels. Any ideas?
Originally Posted by KingsDude
If the EQ is disabled, unmute the line in.
For the no channels, did you set the comport ?
And when you activate, you must have the software running
and let it run untill all channels come in.
[H]4 Life
I'm a lesbian too.
I am for hire!
Frodo - the patch works great! It fixed the scrunched lines and makes it much more readable.
Thanks,
GRod
Carputer/AV System ~95% complete
Parts all acquired - testing underway
Fabrication and integration underway
More on my Ride
1. I haven't activated yet, I thought I would get station 1 before I do that.Originally Posted by frodobaggins
2. Where do I set the comport? I coudln't find it.
Set the port # in the FrodoSatRadX.ini
You should get channel 0 telling you to activate
edit: no, you're right, channel 1
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
Well how do I know which com port to set it to?? As of now, I'm getting no sound and no channels. Do i need to activate right now?? I'm sooo confused.
Also, I can't change channels. I have to set my last channel in the INI file. And when it says its on station 1, it says 00:00 to the right and it desont' change.
Did you connect it to the serial port on the back of the pc? If there's only one on the back of the PC, it will be port 1. if there are two on the back of the pc, it could be 1 or 2. if you connected to the header on the motherboard it should be port 2.
There is only one serial port on the back, so I set it to 1, and it still says the channels are updating and no sound is coming out from Channel 1.
