Serial port enabled in device manager, and bios ?
Sure your cable is good ?
Just called XM to inquire about service fees, and I listened to the recording and it is channel 0. However, I'm still not getting any sound coming from the unit. HELLP!!!
Also, just checked the volume controls. I have the EQ enabled, and on my volume playback, I have line in disabled, and on the recording, I have it selected.
[H]4 Life
I'm a lesbian too.
I am for hire!
Cable should be good. Serial port should also work because I was using it last week.
This is the guy I bought it from:
FS: XM Direct PCR w/ Optical Output & Serial Cable
Check the therad, about 6 posts down there are pics..
Turn off the EQ, unmute the line in, turn up the volumes, and start it again.
Do you hear the unit turn on ?
[H]4 Life
I'm a lesbian too.
I am for hire!
When I plug the cable in, I hear a little clicking noise, so i think that means the unit is on. I did all of the above, and still, silence.
Thats my INI file as of now.Code:[MAIN] SKIN=BLUEDEFAULT800x480 XMPORT=1 LAST_CHANNEL=20 ;Options: TRUE, FALSE FAVORITE_SHOW_CHANNEL=FALSE FAVORITE_SHOW_STATION=TRUE FAVORITE_SHOW_ARTIST=FALSE FAVORITE_SHOW_TITLE=FALSE ;Options: MASTER, WAVE, CD, LINE VOLUME_CONTROL=MASTER ;Options: HARDWARE, SOFTWARE, BOTH MUTE_CONTROL=BOTH ;If MUTE_CONTROL=SOFTWARE or MUTE_CONTROL=BOTH, choose which line to do this action. ;Options: MASTER, WAVE, CD, LINE MUTE_SOFTWARE_CONTROL=MASTER ;Options: MASTER, WAVE, CD, LINE, NONE MUTE_LINE_ON_EXIT=NONE ;Options: MASTER, WAVE, CD, LINE, NONE UNMUTE_LINE_ON_START=NONE VOLUME_PERCENT_CHANGE=3 ENABLE_EQ=FALSE [SIZE] FULLSCREEN=FALSE MOVELOCKED=FALSE ;In Pixels: APP_LEFT=0 APP_TOP=0 APP_WIDTH=800 APP_HEIGHT=480
don't plug the xm into your pc, plug it into a separate stereo if you can, just to see if sound's coming out
I plugged it into my TV via an RCA cable, and all i heard was noise. When I changed the equalizer around and played w/ the settings I got nothing. Just lots of noise.. Hmmmm
I think your cable is ****ed.
[H]4 Life
I'm a lesbian too.
I am for hire!
btw i meant you still have to control it w/the pc and the serial cable, but put the sound to another device so you don't ahve to worry if the equalizer/etc is set right, in case i was unclear
Hmm.. Yeah, I just reinstalled the program, and all the channels came up, but still buzz on the tv. I dont think the cable is the problem because when I take the cable out, the buzzing goes away!! AHHH!! I'm so frustrated.
