*Release*[SAT RADIO] Alpha 3
Here is Alpha 3 of FrodoSatelliteRadioX.
You need to edit the FrodoSatRadX.ini file before use.
Should be self explanatory.
FrodoSatelliteRadioXAlpha3.exe
Notes!
To use the eq, you must have the XM unit audi run through your
computer through something like line in.
---Also, make sure you set your windows mixer record settings to
---the proper line before launch...if it's set to wave or master..
---get ready for FEEDBACK !!!
If you are using the EQ, leave the playback line of the selected
input muted ! Also, be sure to make sure the app isn't messing
with the mutes on start.
To disable the EQ, you can edit FrodoSatRadX.ini
Have Fun guys.
Frodo
