Look in frodoplayer.ini
HIDECURSORGLOBAL=false
should be
HIDECURSORGLOBAL=true
Is it possible for the mouse cursor to hide during full screen mode? Or just hide it period whenever FP is running?
I don't think anyone would need to know where the mouse is if you're running a touchscreen.
should be
dammit... i knew i didn't look hard enough in that ini file.... thanks!
It's also in the settings menus...Originally Posted by ummagawd
[H]4 Life
I'm a lesbian too.
I am for hire!
had a question on something else that's still noticable once you turn off the cursor, is there any way to turn off the windows popup box thingy when your cursor is hovering over something? would do a search except I don't know exactly what they are called and I don't think i'd find anything usefull searching for windows popup box thingy.
2005 Dodge Magnum RT, Samsung Galaxy Tab install
tooltips?
Disable tooltips in the .ini settings
hey frodo, just FYI when i click the option to hide the mouse i have to restart FP and its good [should i have to restart FP, or should it happen on the fly].....BUT after coming out of hibernation the dam cursor is back and i have to repeat the process of shutting down FP and restartingOriginally Posted by frodobaggins
Umm, never noticed that before....frodo is this in the setting menu too?Originally Posted by thanatos106
I have that same problem. I dont have to completely shut down FP to get rid of it, just minimize it and click on some other windows program. (I keep notepad open in the background) Once you've clicked on that program, you can go back to FP and the mouse will be gone. [This only works if you actually click on notepad, just minimizing FP and reopening it wont do the trick]Originally Posted by camsgs3
