It should automatically load and start playing... if it doesn't then you need to install the things in the frodoplayer system requirements faq page. I had the same problem as you....
I cannot seem to get it to work, if it is even supposed to. I have the CD drive setup to the correct drive letter but I do not see how to access the CD in the music player.
Any help?
I have got everything loaded I believe... I just redownloaded everything again, and it was all installed.
I am using MCE 2005 however, not sure if that makes a difference. Is there something I need to change in windows media player to get it to work?
Did you go to CD Mode ?
[H]4 Life
I'm a lesbian too.
I am for hire!
Oh, and right now, mixed mode cd's won't work.
If the CD has a data track, that's what it will find.
[H]4 Life
I'm a lesbian too.
I am for hire!
CD mode?? where is that? I have the fribrumet skin and I do not see it anywhere in any menus or settings options...
<-- truely a newb
then check in the settings to make sure that mode is enabledOriginally Posted by sivart321
[H]4 Life
I'm a lesbian too.
I am for hire!
Ahhhh, yes! Thank you so much! Works great now! What do I need to do to get the track names?
NM, got that to work too..
Scratch that... CD track names and album names show up in WMP, but not in frodo player.. is that normal?
