Results 1 to 4 of 4
Thread: FM and return to MENU (problem)
    Constant Bitrate pijo1971's Avatar
    Nov 2004
    Novara - Italy
    Hi,
    I've this problem... when I enter in FM section I don't have the possibility to return back, i push the menu button but nothing matter... the only way is to exit from frodoplayer.
    I'm using radiator with cinergy 600.
    thanks to all,
    luigi.
    Jan 2003
    Ruston, LA
    Quote Originally Posted by pijo1971
    Hi,
    thanks to all,
    luigi.
    Let me guess, using brushed metal skin ?
    The button is ****ed in that skin.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Nov 2004
    Novara - Italy
    no, i'm using the BrightLife Skin.
    bye,
    Luigi.
    Nov 2004
    Novara - Italy
    I have solved the problem... it was in "Radio.ini" file of BrightLife Skin.... the MINIMENU configuration wasn't defined.
    I have put this configuration and then it's ok.
    MINIMENU_LEFT=10
    MINIMENU_TOP=81
    MINIMENU_WIDTH=18.75
    MINIMENU_HEIGHT=15.625
    MINIMENU_EXIT_LEFT=0
    MINIMENU_EXIT_TOP=0
    MINIMENU_EXIT_WIDTH=50
    MINIMENU_EXIT_HEIGHT=100
    MINIMENU_MINI_LEFT=50
    MINIMENU_MINI_TOP=0
    MINIMENU_MINI_WIDTH=50
    MINIMENU_MINI_HEIGHT=100
    I've also another question... wath does it metter when i click on "TUNE" button or "NUMPAD" button?
    Thank you.
    pijo.
