Results 1 to 7 of 7
Thread: First time user - screen is shifted
    Newbie ErikGreen's Avatar
    Jul 2004
    Minnesota, USA
    Hello - I just installed Frodoplayer on my system, and while it looks like a neat application, the display is shifted down. (screenshot attached).
    What am I doing wrong?
    System specs:
    Via TC10000
    256MB RAM
    60GB HDD
    Windows XP professional
    Lilliput 7" display w/eGalax
    Drivers for: bluetooth, 802.11, GPS, egalax, video, audio, LAN updated from Internet
    Screenshot:
    Frodoplayer installed and running?
    Thanks for any help,
    Erik
    PS: I'm planning on getting Iguidance 2.1 to install on this as well.
    Constant Bitrate Heckle0's Avatar
    Sep 2003
    Colorado Springs
    From the looks of things it could be your resolution setting. Make sure that you have them matched. Whatever sking you are running (800X480 or 800X600) should match the resolution of your screen. There is also a setting in Frodo referring to the "ini" setting. Uncheck that too.
    Another Novice?
    Progress so far <-------*-> 88%
    Kenwood MPV5025 with Aux
    Via MII10000
    512MB Ram
    LG Slim DVD\CDRW
    Xenarc 700TS
    M1ATX
    Pharos GPS
    SYBA USB2.0 4-port Hub
    Bufalo 54Mbs Wirelessb/g PCMCIA card
    Constant Bitrate Willy-Mach1's Avatar
    Mar 2005
    Laurel, Maryland
    I had the same problem the first time I used frodoplayer. It is actually a display setting within frodoplayer, i forget what it is called, it's something along the line of fullscreen or something like that....damn!! I can't remember it!!!! I found the solution here on the forum....maybe some will help you out
    Progress: |##########| 99.99%
    - Tweaking and enjoying!!!! Never really done.....
    -= MachPuter Project =-
    -= MachPuter Project Worklog=-
    Mar 2005
    Laurel, Maryland
    Frodoplayer starts partly outside window ?
    I think that is your solution!!
    Jul 2004
    Minnesota, USA
    I'll give it a try as soon as I get home! Thanks!
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    That's it. Uncheck advanced settings or edit them in the .ini file if you can't get to the settings button with that skin.
    Want to:
    Jul 2004
    Minnesota, USA
    That got it - thanks for the help =)
  1. Replies: 21
    Last Post: 08-27-2006, 02:26 AM
  2. Frequently Asked Questions
    By bgoodman in forum The FAQ Emporium
    Last Post: 05-03-2005, 07:25 PM
  3. Opus150w+hibernation=blue Screen Of Death
    By NYCdesignkid in forum Power Supplies
    Last Post: 03-28-2005, 06:57 PM
  4. What screen should I use?
    By NS98GSR in forum General Hardware Discussion
    Last Post: 01-02-2004, 09:11 PM
  5. Screens and Nits and Blown bits which screen do you use
    By belezeebub in forum LCD/Display
    Last Post: 12-23-2003, 04:08 AM
