Known issue - For me when you hibernate and get back into Frodoplayer, my system volume goes down to 0 and its a pain to change that through just the touchscreen. I think Frodo said he was going to fix that for his next version.
I've got the following problem:
I adjust the Master Balance in the Windows Mixer a little bit to left (because my right speaker is louder then my left one).
But when I hibernate my PC and starts it again from hibernation, the balance slider is readjusted to the middle in the Windows Mixer.
But now the main problem!
This only happens if I use Frodoplayer and than hibernates.
If i don't have Frodoplayer started, adjust my Balance, Hibernate, and then restart my PC from hibernate the slider is still at the same position where i had adjusted it before.
How to solve this problem?
I can't find any equalizer or something else in Frodoplayer...
Tried SetVolume?Originally Posted by PDiddy
Yeah, I know =P Got no idea... sryOriginally Posted by halve85
now i have a workaround for my problem.
I use the KX-Drivers Project for my Soundblaster Live!
In the DSP you can build your very personalised own Sound Setup - like in a big Sound Studio! You can cut frequences, adjust the volume per channel and many other things i do not need ;-)
BIG sound in my small ar ;-)
