Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: New Skin in the making. need your help
    Constant Bitrate lominono's Avatar
    May 2005
    Hi im just starting out with this new skin. here is what i have so far:
    okay three things:
    1. what should i call this?
    2. what do you think?
    3. anything you would like to add?
    this is the first skin i am attempting so its prob gonna be a while before completed so any help would be greatly apprieciated.
    thanks for the input in advance
    okay after my first atempt, of skinning frodoplayer, i did not like how polyplayer ended up so i have dumped polyplayer. i have started a new skin SimpleSkin. if you scroll down like 5-8 posts you will see it there.
    Nov 2004
    St Louis
    Honeycomb blue and make all the button in that same shape with a lighter color.
    May 2005
    which shape?
    round off the edges like the center square?
    i didnt get around to changing the color of the buttons yet. i was think like a dark skyblue type or just transparenting it a little.
    i dont like the bottom thing so i will either lower the transparency or just not do the transparency
    Aug 2004
    Germany
    I think he meant that the buttons should have the honeycomb shape
    Nov 2004
    St Louis
    Quote Originally Posted by Konrad
    Right!
    May 2005
    okay umm like this
    choice1:
    choice2:
    i thought about this but the honeycomb im using isnt straight. its off centered just a bit so if i used that the buttons it would be crooked. i cant find any honeycomb patterns that are straight.
    if you look at the where the honeycombs are cutoff at the left of the screen you can see what im talking about. if i can find a pattern that is straight i will try it.
    Variable Bitrate Frigor's Avatar
    Aug 2004
    Faenza, Italy
    what about this?
    BMW E36 Project [ =======§== ]
    Hardware:
    Lilliput 7" Touchscreen - Epia M-10000 - HQCT 1.0 FM Radio - 2.5" 80Gb - USB GPS
    Software:
    FrodoPlayer 1.10 & MapMonkey with FriBruMet Skins by Frigor.
    Variable Bitrate proTONEd's Avatar
    Jun 2004
    Belgium
    Looks good to me. Keep up the work.
    Be sure to test though whether the contrast is high enough. You will be pleased on the sunny days.
    Why is it drug addicts and computer afficionados are both called users?
    Currently : Audi A6 - no install
    Second install : VW Passat '97 CarPC
    First install : '87 Audi 80 CarPC
    May 2005
    okay i have increased the size of the header and buttons to make it more ts friendly, made the polyplayer logo, and lowered transparency of the center square and the bottom bar. i like the name polyplayer so i used that. here is the skin as of 5/21/05
    i still dont know what to do with the buttons. since the logo came out good to match with the white buttons there now i think i might work with something whitish. the header doesnt match so i might change it.
    i am also thinking of doing the play, pause, stop,... buttons using the 7 hex pattern like the logo.
    so what do you think so far?
    Jun 2004
    Belgium
    Why not try to keep the white tint for the buttons and just giving it a special edge effect. Or add a thin dark blue or black line to them. That way the plain white surface is broken a little. Experiment with some blue text on top of the buttons, that could already be world of difference.
  1. Any chance on someone making an 800X480 skin?
    By BoyNextDoor in forum Centrafuse
    Last Post: 04-24-2005, 03:05 AM
  2. My first attempt at making a skin
    By Nanozic in forum FrodoPlayer
    Last Post: 03-27-2005, 02:37 PM
  3. Replies: 0
    Last Post: 02-05-2005, 11:39 AM
  4. Making my own skin - Preview Inside
    By icet in forum FrodoPlayer
    Last Post: 01-20-2005, 09:29 AM
  5. im making a skin and got a question
    By damixt in forum FrodoPlayer
    Last Post: 12-31-2004, 04:30 PM
