Results 1 to 6 of 6
Thread: Return to menu
    Mar 2005
    Melbourne, AUS
    Return to menu
    I want frodoplayer to return to the MENU screen after I have used my apps (eg.GPS...), so in the frodoplayer.ini file a changed:
    RETURNTOMENUFROMFUNCTIONS=TRUE
    yet it doesn't return to the menu instead just opens the 'regular screen.'
    does anyone know what to do?
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    That setting is just for when you firts open FP (it will way until you click in one of the options of the menu to go there) other way it will go to the media menu.
    Mar 2005
    Melbourne, AUS
    So is there no way to enable frodoplayer to return to the menu after using a program?
    Maximum Bitrate Maņana's Avatar
    Jul 2004
    Sweden
    No, that should work.
    Holding the menu opened untill you click something isnt affected by this. That is a different parameter called "holdmeuopenuntillclicked=false" or something like that. (havent got the frodoplayer.ini here, so can't check)
    Also, there is another parameter that controls if you get to the menu or player window on player launch, something like "openmenuonlaunch=false" or something like that.
    Will check further when i come home.
    Mar 2005
    Melbourne, AUS
    Thanks for the advice guys,
    will give it a try
    Nov 2004
    The instrution that manana gave you are to do the same thing but with the .ini file (both should work) mine is just the way to make via the gui
  1. RR Menu to emulate MM Menu button
    By GizmoQ in forum Map Monkey
    Last Post: 09-05-2006, 03:02 PM
  2. question about the menu dissapearing after 5 secs
    By lominono in forum FrodoPlayer
    Last Post: 05-29-2005, 12:06 AM
  3. FM and return to MENU (problem)
    By pijo1971 in forum FrodoPlayer
    Last Post: 04-12-2005, 08:52 AM
  4. Menu always on top, other new features
    By clean customs in forum FrodoPlayer
    Last Post: 01-22-2005, 05:27 PM
  5. How to setup gps button in menu
    By Tyrael in forum Media Engine
    Last Post: 02-25-2004, 03:53 PM
