what we want to achieve is to have MM ready in the background so if we hit the GPS button the map will be ready. (no MM logo or waiting for gps signal or all the things that happen when you hit the button)
Launch Options (GPS)
Album art?
Is like if I put the MMlauncher in launch options it will launch it but in top of FP.
Thanks in advance
use the same code and change the 0 to a 7
WSH.Run "test.bat", 7
[H]4 Life
I'm a lesbian too.
I am for hire!
so where "test.bat" is = MapMonkeylauncher.exe right?? no MapMonkey.exe because that is the tricky part I think...
Thanks Frodo.
Originally Posted by thanatos106
"test.bat" is whatever program you need to run minimized.
Here is a reference for that object:
http://www.winguides.com/scripting/reference.php?id=148
http://www.winguides.com/scripting/reference.php?id=109
[H]4 Life
I'm a lesbian too.
I am for hire!
As you can see, 0 hides, 7 minimizes with no focus.
[H]4 Life
I'm a lesbian too.
I am for hire!
This is the file info:
Dim WSH
Set WSH = WScript.CreateObject("WScript.Shell")
WSH.Run "C:\DestinatorApps\Map Monkey\MapMonkeyLauncher.exe", 7
And the pic is the error:
Sorry, it's an escaped character problem.
Do this:
WSH.Run """C:\DestinatorApps\Map Monkey\MapMonkeyLauncher.exe""", 7
[H]4 Life
I'm a lesbian too.
I am for hire!
Well the above info resolve the error problem but when I hit the gps button I still have the "loading plugin" window
Also after doing this volume goes up to 100%![]()
I guess Map Monkey isn't very smart.Originally Posted by thanatos106
Wierd.Also after doing this volume goes up to 100%![]()
[H]4 Life
I'm a lesbian too.
I am for hire!
