Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
Thread: Launch program minimized
    Maximum Bitrate Maņana's Avatar
    Jul 2004
    Sweden
    When frodoplayer starts, I've told it to launch a batch file whitch launches a few programs. Now, this batch file starts above frodo, and is visivble for a few seconds. Is there a parameter to make frodo launch the batch file minimized?
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    I have the same problem... and I have yet to find a solution from the batch file side...
    Elsewhere
    Quote Originally Posted by Maņana
    Code:
    @ECHO OFF
    Add that as the first line of the batchfile, and you won't see any output. You can also make a PIF for the batchfile that will make it run minimized.
    How about the Wiki?
    Aug 2004
    Pearland
    I will try a .PIF file... but the @echo off wont make the actual window disappear...
    Jul 2004
    Sweden
    Quote Originally Posted by some website =P
    Instead of creating a .PIF file, which NT doesn't use, you create a shortcut to the batch file and edit its properties. Then you choose Shortcut -> Run -> Minimized and Options -> Display Options -> Window. Now you have a batch file that launches silently when double-clicked but NOT from Director's "open" command for some reason, where it still insists on displaying a window.
    But frodoplayer cant launch a shortcut, and i can't get the pif file to work properly :s
    Jan 2003
    Ruston, LA
    ah, gimme a minute
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    I hanging here until you get the solution........
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    Jan 2003
    Ruston, LA
    Make a file similar to this with a vbs extension.
    For example, my file is called "test.vbs"
    And tell fp to launch it.
    Replace "test.bat" in the code with the path to your batch file.
    Code:
    Dim WSH
    Set WSH = WScript.CreateObject("WScript.Shell")
    WSH.Run "test.bat", 0
    This requires you have Scripting Installed, which, in all likelyhood you
    do.
    Frodo
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Nov 2004
    Ok I will try this in the morning....(becouse I also have the same prob)
    Thanks frodo..
    Also in a couple of threads Manana and I asked how to do something similar to this but with MM (last time I checked there wasn't an answer) any quick word on this matter??
    Nissan Aux-in MOD
    Jan 2003
    Ruston, LA
    Quote Originally Posted by thanatos106
    Thanks frodo..
    Explain better or find me the thread
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  1. AC97 Control Panel Switcher Program (could be useful for many)
    By Vinister in forum Software & Software Development
    Last Post: 02-02-2005, 03:50 PM
  2. Can this program be made for MediaCar?
    By carpcnoobie in forum MediaCar
    Last Post: 12-01-2004, 02:20 PM
  3. Looking for a program.
    By Mikesz in forum Software & Software Development
    Last Post: 11-23-2002, 06:09 AM
  4. Running a program inside a program
    By CaffeineAddict in forum Software & Software Development
    Last Post: 10-16-2002, 03:26 AM
  5. charchter lcd program?
    By Jaymz in forum Software & Software Development
    Last Post: 02-15-2001, 07:32 PM
